Page 60 of 220 FirstFirst ... 5859606162 ... LastLast
Results 591 to 600 of 2192
Thread: AB's new GQ is finally here
  1. #591
    Patrol God Stropp's Avatar
    38 Post(s)
    All done, holds the shape really well but without that wire insert they would look like a bag of poo.
    Pissing rain so ill take some better pics out of the carport soon!
    You must use silicone spray to run that wire aswell
    looks the ticket AB, getting there with the mods mate .
  2. The Following User Says Thank You to Stropp For This Useful Post:
    AB (23rd December 2014)
  3. #592
    looking sweet AB
  4. The Following User Says Thank You to Clunk For This Useful Post:
  5. #593
    Happy to show people a little error I made so others don't do the same.
    Don't mount the last fixing so close to the bottom of the arch on the rear of the front arches as pic below.
    The concave of the arch tapers back towards the body which pulls the rubber flare and curls it inwards towards the tyre.
    Should really mount that last fixing at least 50-80mm before the end (keep parallel with previous fixings) and just let the rest hang down.
    It's only the rear of the front arches.
    I didn't realise until I put the tyres back on and ran the wires damn it!!!
    I was thinking of running some steel plates to push it back out and to hold the front mud flaps but then the plates will just get smashed when offroad on rocks, etc.
    Front tyres off and move that fixing back a bit I think! 1st world problems!
  6. The Following User Says Thank You to AB For This Useful Post:
    growler2058 (23rd December 2014)
  7. #594
    Just pull the wire out and cut a bit off AB. leave the wire 100mm short at each end and it should not curl like that.
    Note also that the Wire is a Shocker for working its way out of the flare and stabbing you in the leg or the side wall of the tyre. Insert a Self Tapper into each end of the flare to stop this from happening.
  8. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (23rd December 2014), Clunk (23rd December 2014), growler2058 (23rd December 2014)
  9. #595
    Thanks mate, I just pulled out 200mm from the front but it still curls.
    See below how that last rivet sits inwards from the rest, wouldn't that be the culperet?
  10. #596
    can you put a washer behind it? maybe less pressure.
  11. #597
    Feb 2011
    Shed
    45 Post(s)
    300mm strip of hoop iron riveted to the flare will sort it out. I did mine all the way
  12. The Following User Says Thank You to growler2058 For This Useful Post:
  13. #598
    Nah it's definitely pulling in and would need a gigantic washer 100mm diameter.
    Thought it may have been the spring loaded wire pulling but just managed to do a full rotation of the wire and no joy.
  14. #599
    Worked it out, it's the bloody wire curling it inwards and the fixing too low..
    Need to manually shape it back up
  15. The Following User Says Thank You to AB For This Useful Post:
  16. #600
    That's what I said choppa ! The same happened to mine.
    Make sure you fit a self tapper to each end mate or the wire will come out every drive.
