Page 448 of 1057 FirstFirst ... 446447448449450 ... LastLast
Results 4,471 to 4,480 of 10561
  1. #4471
    Far out mate. Last outing gave you a bit of grief eyy...
    I had the Patrol on stands before, cleaned, high pressure washed and gave it a good drenching with Ct18 underneath. Replaced air filter, cleaned MAF, took intercooler off and gave it a good clean and degrease as it was full of oil.
    Rolled the winch rope out and gave that a nice clean as well. Time for a few coldies now...
    Havent you got a catch can fitted ??
  2. #4472
    To make things worse the rear lower bolt on the alternator wont budge and if I try harder I feel the bolt will just round off. Then Im stuffed.
    As suggested give it a good squirt and plenty of CRC or similar,
    probably just mud under the brushes
  3. #4473
    176 Post(s)
    Yup, and it's catching heaps, but still IC is full. One of many items, not quiet right under the hood of my trol.
    475 Post(s)
    Done all that john. Managed to get the charge light and sub tank light off but its only charging at no higher than 12.7v. Its should be around 13.8v shouldn't it?
    The charge actually drops when it rev it.
    BigRAWesty (21st December 2014)
  6. #4475
    Patrol God Stropp's Avatar
    36 Post(s)
    Yes mate around 14 volts when revved
  7. #4476
    .......... TPC's Avatar
    63 Post(s)
    Do you have or can you borrow Metrinch sockets? They cannot round off bolt heads.
  8. #4477
    475 Post(s)
    If in doubt, soak the effer in everything you have! Then hit it with the blow torch. Lol! Finally came loose.
    TPC (21st December 2014)
  10. #4478
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Almost finished my rear door table, can't wait to use it, just need some nutserts for the trim clip holes, and some bolts to suit and it should be sorted.
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  11. #4479
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Finally cleaned all the NT dirt off the car, now to find some good QLD mud.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  12. The Following User Says Thank You to Ian2011 For This Useful Post:
    Stropp (23rd December 2014)
  13. #4480
    Feb 2011
    Shed
    45 Post(s)
    Cleaned the white overspray off the black flares
  14. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    Clunk (24th December 2014), Stropp (23rd December 2014)
