Results 1 to 6 of 6
Thread: Swivel Housing
    Nov 2014
    Swivel Housing
    Hi All,
    Just after some advice on the Swivel Housing's in the attached photos, is there a current problem or possible future problem that anyone can determine form these photos? If so what maintenance / repairs may I need to do?
    Thanks in advance
    Drivers Side
    Passenger Side
    Passenger Side 2
    Feb 2011
    Shed
    45 Post(s)
    Swivel hub seals
    Shitload of really good how to threads here on this one mate
  3. The Following User Says Thank You to growler2058 For This Useful Post:
    Tigger77777 (17th December 2014)
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    A swivel rebuild kit off eBay should set you right. Straight forward to change. If you ignore it, it will only get worse.
  5. The Following User Says Thank You to Parksy For This Useful Post:
    334 Post(s)
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  8. #5
    Nov 2014
    Thanks guys for the advice, this will put me in the right direction
  9. #6
    Nov 2014
    I did the rebuild last weekend and all went well, thanks to your guide. Cheers
    1994 GQ 4.2L Y60 turbo Diesel Patrol ute (was a wagon), 4 inch lift, 2 inch body lift, 33 inch Maxxis Bighorn Tyres, endless air compressor, front and rear lockers, 25L water tank, endless hot water, winch, rock lights, reverse camera, dual battery.
  10. The Following User Says Thank You to Tigger77777 For This Useful Post:
    MudRunnerTD (11th February 2015)
