Results 1 to 10 of 13
Thread: replacing central locking
    Feb 2012
    Aldinga Beach, sa
    Hi everyone tomorrow im going to replace my central locking in my 92 gq. I was wondering which way the standard locks unlocks from the positive or negative. I am going to put some aftermarket locking system in (cyclops).
    I was also wondering if I could just keep all the factor wires and just replace the motors themselves.
    Thanks for all your assistance.
    Unsure mate. Might just have to test it.
    But I went a complete stand alone system with keyless entry and added a second master to passengers door. Placed the 4th kit actuator in the rear door..
    Feb 2012
    Aldinga Beach, sa
    Thanks I will have a look and see if it will work.
    The aftermarket one I have is a complete kit and I got an extra one for the rear door.
    I will be starting it shortly and I will let you all know how it goes
    Feb 2012
    Aldinga Beach, sa
    Sorry got the make of the aftermarket kit wrong its a trackpro
    I have started and now im stuck I having troubles working out where to mount and install the new units. I am unable to resue the factory wires as the new unit has 5 wire for the front units.
    Can anyone help me please
  5. The Following User Says Thank You to 4wdnut2012 For This Useful Post:
    BigRAWesty (14th December 2014)
    It is. Should have remembered that.
    I'll try find my diagrams but I'm pretty sure the the 2 wires coloured the same as the other (green and brown from memory) will activate the unit. The other 3 and for the auto setup.
    Now the patrol uses 3 so I'm unsure how that works but I'll assume the master sends a signal back to controller unit.
    Like I said I just installed stand alone so from here on in I'm blind.
    I mounted mine in place of original actuators and ran rods in place solid fixed. I did not use the clamp crop they supply. I'll see if I can find some pics
    Feb 2012
    Aldinga Beach, sa
    The wires on the aftermarket are blue and green. I ill put a couple of photos up
    Feb 2012
    Aldinga Beach, sa
    Feb 2012
    Aldinga Beach, sa
    The fist photo is the master unit, there is 2 of them. The wire colours are green, blue, white, brown and black.
    The second photo is the other doors I have 3 of these. The wire colour are blue and greeen.
  10. #9
    Exactly the same as mine. So your blue and green are what throw the until in and out.
    The other 3 are signal wires. Tbh I don't think it can be done. For some reason the new units need the 3 signal wires. The originals only need one.
    Feb 2012
    Aldinga Beach, sa
    So the front 2 doors have 3 factory wires and all the bach doors have 2 wires then.
    The back door (boot) only has the 2 wires going to it.
