Results 1 to 10 of 10
Thread: GU-I Indicator/Parker plastic lamp inserts
    Advanced iRide's Avatar
    Sep 2014
    Brisbane, QLD
    Angry GU-I Indicator/Parker plastic lamp inserts
    Hey all,
    Basically the story goes like this.....
    I have the genuine Nissan steel winch bar (ARB Deluxe Winch) and recently I have bought myself some new Narva LED indicator/parker lamps for the front!
    ONE SMALL PROBLEM!!!!
    The original lights in the bar are smaller and sit in this horrible little plastic housing to sit front on, the idea of these new Narva ones i have are that they sit flush and pretty!!!
    Any suggestions on what I can do as these new units will not fit in the original plastic housing, and once you remove it, the gap is far to huge to mount anything!!!!
    Have spoken to ARB and Nissan, and they don't want to seem to help me at all
    Does anyone know of any other plastic inserts you can use for this bar to make them work?? Or is this one of those situations in which I make some form of horrible looking bracket???
    Any help is muchly appreciated!!!!! I have attached a couple of pics, one of the current horrible set up, and one of the new indicators in question
    PM Mudski he just had some led park/indicators fitted,
    can you drill two holes either side of the cavity and then bolt the lights up?
    brisbane
    Yea I think that's how you do It as threedogs mentioned, the one you bought fits the front by drilling and bolting it on without the plastic insert if you wanted the insert you would use this size. Double check the measurements though.
    http://www.ebay.com.au/itm/PAIR-LED-...-/111132965348
    I'll be doing this soon as my led bulbs are rusted into the housing
    @ Mega are they indicator only, as that would suit my set up better,
    with my DRL hooked up to the parkers
    brisbane
    I know you can get indicator only you would just have to look around.
    the ones iride put up certainly do. It depends if you want to retain the plastic insert.
    http://www.elecspess.com.au/files/Ne..._52_NPR_v5.pdf
  6. The Following User Says Thank You to megatexture For This Useful Post:
    threedogs (14th December 2014)
    NT
    The ones you have are fine.
    Remove old parker/blinker.
    Remove insert from bull bar. Use Dremel to trim insert, so the new Parker fits into it. See my pics - it seems a bit messy, but the light covers the roughness.
    Cut some scrap sheet metal, drill holes and bend at least 90 degrees. I used nut and bolt from bracket to Parker, and rivet from insert to bracket. The rivets are visible from the outside.
    'scuse the dirt
  8. #7
    brisbane
    How do the look lit up ?
  9. #8
    NT
    Haven't got a clear pic at the moment. They look good when clean. Here's what they look like on the road with parkers on.
  10. #9
    brisbane
    Cheers, they look a lot better then the 50/50 ones
    I might see if they have ones that will fit without modifications
  11. #10
    Sep 2014
    Brisbane, QLD
    Quote Originally Posted by p4trol View Post
    the ones you have are fine.
    Remove insert from bull bar. Use dremel to trim insert, so the new parker fits into it. See my pics - it seems a bit messy, but the light covers the roughness.
    Cut some scrap sheet metal, drill holes and bend at least 90 degrees. I used nut and bolt from bracket to parker, and rivet from insert to bracket. The rivets are visible from the outside.
    'scuse the dirt
    awesome idea lad!!! I shall be attempting this!!!
