Page 443 of 1057 FirstFirst ... 441442443444445 ... LastLast
Results 4,421 to 4,430 of 10561
  1. #4421
    Quote Originally Posted by lucus30 View Post
    You still coming on Sunday?
    Nah mate no $$$ plus not going anywhere until I can stand for at least 5 minutes, just too painfull
  2. #4422
    Patrol God Stropp's Avatar
    36 Post(s)
    received my supapeg custom awning today, got a 5% discount plus an led stip and sand peg kit free by mentioning the facebook special so i was happy with that, now to fit it up over the weekend.
  3. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    DX grunt (14th December 2014), threedogs (9th December 2014)
  4. #4423
    @ Stropp as per pic my LED strip light worked a treat ,that was the only time Ive used it tried it again last weekend and only 1/3rd worked .
    So I ripped them off and threw them in the bin, Im now going to use 200mm cob strips that some use as DRL will only need two they are very bright.
    http://www.ebay.com.au/itm/161275684...84.m1423.l2649 They are very bright
  5. #4424
    36 Post(s)
    i have leds on the current awning and have fitted a dimmer to it so i can control the light, it also pulses and flashes but i mainly use the remote with the dimmer. i think i will do away with the remote on this one.
  6. #4425
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Saw it leave on the flat bed off to its final resting place
  7. The Following 4 Users Say Thank You to 93patrol For This Useful Post:
    AB (9th December 2014), cgm (9th December 2014), Clunk (9th December 2014), Stropp (9th December 2014)
  8. #4426
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
  9. #4427
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Installed new coil packers 15mm to replace the rubber insulators that are stuffed. Backs done and front tomorrow
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  10. #4428
    475 Post(s)
    You should have done it when you did the springs...
    big_fletch (10th December 2014)
  12. #4429
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Finally fitted my rated recovery points to the front, passenger side was a bit of a pain, but glad it's done now�� also wired in my connectors for my UHF antenna lead so I can disconnect the bar from the front without having to cut the wire at the time.
    Worth mentioning is my recent arrival and fitment of my roof bars, got them from ebay for $189.00 for three bars, fitted them up, and no wind noise, work really well. So much cheaper than the local stores!
    If anyone wants the link just let me know, and I'll post it, only thing worth mentioning is they do have locks, but it reckon I could unbolt them even with the locks. Still, I am otherwise very happy with them, and soooo much cheaper
    Last edited by Patrol'n; 10th December 2014 at 12:52 AM. Reason: Wanted to add more info
  13. #4430
    Oct 2010
    Tatura VIC
    Yer I know also should have done the castor correction but I'm doing that before the weekend as well hahaha
    Apprentice Sparky
