Page 59 of 220 FirstFirst ... 5758596061 ... LastLast
Results 581 to 590 of 2192
Thread: AB's new GQ is finally here
  1. #581
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    I'm considering mounting the Bushranger flexi flares using stainless steel pop rivets and I'm trying to find some washers to suit just in case it pulls through the rubber.
    The custom folds are tight (would still work using bolts but tight) and it would make cleaning mud easier as well. I do not want to drill screws or tek screws in there, I can't stand that!
    Thoughts on this? Haven't seen many people doing it so I'm second guessing...lol
    Being to a few local shops and no joy on washers that small either?
    Use a strip of Aluminium instead of washers, doesn't need to be as wide as mine but will support the flare nicely.
    Dab of sika on the rivet will seal up the hole also and help prevent rust.
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  2. The Following 2 Users Say Thank You to Crate For This Useful Post:
    AB (3rd December 2014), lucus30 (3rd December 2014)
  3. #582
    Quote Originally Posted by Crate View Post
    Good idea on the thin strip of ally if the washers don't work out mate.
  4. #583
    Patrol God Stropp's Avatar
    38 Post(s)
    Yes when I had rubber flares I had a thin metal strip on the rubber and riveted it on, very sturdy and no chance of pulling thru.
  5. The Following User Says Thank You to Stropp For This Useful Post:
    Winnie (5th December 2014)
  6. #584
    Decided on some much larger SS rivets and found some washers to suit which won't pull through.
    Install tomorrow!
  7. The Following User Says Thank You to AB For This Useful Post:
    Stropp (5th December 2014)
  8. #585
    Can't wait to see it
  9. #586
    38 Post(s)
    goodluck mate, while you are doing that i will be camping at Meerup river with wa489 and doggie and a couple of those other not so good 4wd's drinking bourbon and ginger beer
  10. The Following User Says Thank You to Stropp For This Useful Post:
  11. #587
    Punch doggy in the neck for me really hard
  12. The Following 3 Users Say Thank You to AB For This Useful Post:
    Bloodyaussie (5th December 2014), Clunk (5th December 2014), MudRunnerTD (5th December 2014)
  13. #588
    Putting the flares on and didn't realise how hard something must have hit the hard nose. Pushing up against it too.
  14. The Following User Says Thank You to AB For This Useful Post:
    Stropp (23rd December 2014)
  15. #589
    Mine is the same. I winched it back out and bent it in again last weekend. It doesn't take much
  16. The Following User Says Thank You to Winnie For This Useful Post:
    AB (23rd December 2014)
  17. #590
    All done, holds the shape really well but without that wire insert they would look like a bag of poo.
    Pissing rain so ill take some better pics out of the carport soon!
    You must use silicone spray to run that wire aswell
  18. The Following 2 Users Say Thank You to AB For This Useful Post:
    Clunk (23rd December 2014), Stropp (23rd December 2014)
