Results 11 to 20 of 30
Thread: Advice please?
    In simplest terms...
    Mono are more efficient than Poly panels... IE a Mono panel is about 5% more than a Poly panel.
    For camping this usually doesn't matter all that much as all it means is that a Mono is slightly smaller.
    Poly have a better temperature co-efficient... IE the hotter it is the less "more efficient" the Mono panels become and the Poly will take over.
    For camping Poly is better
    Solar panel performance is dollar related IE a top end panel of the same physical size and cells can be 20% more efficient than a cheapo.
    This means a good Poly will easily outperform a cheap Mono or vice versa.
    Solar panels degrade and the other main difference between manuf is by how much over time.
    Most specs will be, say, "80% of output after 15 or 20 or 25 years" or whatever.
    This means as the panels get older the performance gap between a cheapo and a high end panel will get better and better.
    For a several thousand dollar house array this is quite important.
    For Camping this doesn't matter all that much
    To "top up" a 105 Amp AGM battery that is in a vehicle which is touring or for short term camping and only running a small Engel then an 80 to 100 Watt Array will be oodles.
    I use a 100 watt array and that easily handles 2 fridges, LED lighting and electronics recharging into a 2 X 105 AH Full River AGM battery bank
  2. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    bishbashbosh (3rd December 2014), threedogs (3rd December 2014)
  3. #12
    Expert bishbashbosh's Avatar
    Nov 2014
    thanks all.. time to drop some cash then..
    will look into the poly's as well considering i'm going to be out in hot weather!
    psst - what brand panels do you look for and avoid?
  4. #13
    Just MHO but I am not a big fan of 'hard' mounting panels on a vehicle because;
    You have to park your vehicle in the sun (yes, that is Captain Obvious speaking) and I hate that.
    A panel that is at a poor angle to the Sun can loose 1/3rd to as much as 1/2 it's output which means either a much bigger array is needed or having to move the vehicle... a lot. Much easier to move a free standing panel around in azimuth and adjust the tilt legs.
    With the Alternator running the "extra" few AH from the Panel is either neglible or not used at all or, worst case depending on set ups, can cut out the charge current from the Alternator and only use the few AH's available from the panel.
  5. The Following User Says Thank You to the evil twin For This Useful Post:
  6. #14
    Ballarat, Vic
    176 Post(s)
    Poly or mono not really worth worrying about these days, esp. if A grade. Size difference is very small, buy panels to fit the storage space you have. My preference is for Mono because they are a tad more efficient, but choosing on that basis would only be if all other aspects were equal. I think TD is talking about Amorphous panels when he talks about some panels being much larger for the same wattage.
    Don’t pay extra for the crappy regulators supplied with most panels, best to throw them in the bin & get a reasonable regulator for around $100 or so. Dont even think of using the supplied cables - use them for tying up your tomatoes & get appropriately heavy gauge cable to avoid voltage drop. Not much point having a panel which puts a significant part of it’s output into warming the cable rather than charging your battery.
    Dor portables look for a panel frame design which will stand up well in the wind, some have flimsy legs & can’t be pegged down.
    I’m not over keen on the black frames. Panels become less efficient the hotter they get & black will get hotter than silver.
    Unlike ET I am a fan of roof mounted panels. Having used both mounted & portable, I’ll go with the convenience of mounted any day & am happy to have a bit of extra ‘wattage’ to compensate for the less than optimum mounting angle. Fit & forget rather than having to move the damn things every hour or so throughout the day, or tripping over cables, or worrying about them being nicked. Putting them on a roof with an air gap underneath will keep the car a bit cooler as it creates a ’tropical roof’. Mostly we sleep at night when the sun isn’t shining, so if the bed is in the vehicle it’s not a major issue. If not sleeping in the vehicle it’s not hard to sleep a few metres from the vehicle in the shade. Awnings are handy too.
    When working out your wattage needs, (assuming you know how much your appliances will use) look at the nominal wattage of the panel & divide by 12 (for a 12v panel) & then multiply that figure by 70%. This will give you a realistic estimate of what output you can expect. Eg 120w divided by 12 =10 10 multiplied x70% =7. 7 amps is about what you can expect to see in good conditions (although new panels will often put out a bit more initially).
    Cuppa
  7. The Following User Says Thank You to Cuppa For This Useful Post:
  8. #15
    Nov 2014
    do i need a regulator if i have the ctek d250s dual?
    i am going to hook up the cables using 8B&S directly to the ctek with an anderson plug in between for easy connection.
    googling shops close so i can have a look at the panels atm
  9. #16
    brisbane
    No just connect earth to earth and pos to the bolt with the pic of a panel next to it
  10. The Following User Says Thank You to megatexture For This Useful Post:
    bishbashbosh (4th December 2014)
  11. #17
    Ballarat, Vic
    176 Post(s)
    Ctek D250s Dual is a combined solar reg & dc to dc charger, & I assume a crank battery isolator too (MT can confirm the latter).
    Deciding to use 8 B&S cable to connect panels to battery before you decide whether the panels will be roof mounted or portable, & (if portable how far away from the car you want to be able to place them) is putting the cart before the horse. The cable you need should be determined by the total length of the cable & the current you expect it to carry whilst ensuring an acceptably low voltage drop. Thankfully there are tables available to make this easy to work out. My favourite is this one. http://hobohome.com/news/?p=581 It’s a bit old now but the info in the tables holds good.
  12. The Following User Says Thank You to Cuppa For This Useful Post:
  13. #18
    Ballarat, Vic
    176 Post(s)
    Quote Originally Posted by megatexture View Post
    Is there a misunderstanding here? Having an anderson plug in the solar input line is a good idea I think, at least it’s how I have my setup. Even my current roof mounted panel utilises an anderson plug connection for convenience if/when I need to remove it.
  14. The Following User Says Thank You to Cuppa For This Useful Post:
  15. #19
    brisbane
    Yes your right cuppa, the only thing I havent tested is if it will allow charging of the crank once the aux id at full charge via solar
  16. The Following User Says Thank You to megatexture For This Useful Post:
  17. #20
    Nov 2014
    i've used 8B&S throughout the whole fitout of my dual system - i don't think i'll need any bigger for the solar panels if i run them at 5 metres max?
    will go with 120watt solar panels just to cover all bases - after thinking about it i'd rather not attach them to the roof as this will take up valuable real estate when travelling - don't mind moving them and will fold up and put in back - i got about 1.4 meter (width) x 1 meter (height) x 300mm (deep) behind my fridge to store them.
    i'm thinking to mount an anderson plug next to the baintech power panel i have already fitted - that way i can just plug in the solar panels as needed without needing to fiddle with the ctek which sits under my wing cover of the drawers. what size amp anderson should i purchase you think?
    should i remove the connection boxes that connect the panels and upgrade them to something better or is it just a case of removing the regulator and using the ctek?
    aux battery - ctek = 1 metre
    ctek - anderson = 500 mm
    anderson - solar panels = 5 metre (max)
