Page 441 of 1057 FirstFirst ... 439440441442443 ... LastLast
Results 4,401 to 4,410 of 10561
  1. #4401
    Western suburbs of Melbourne
    11 Post(s)
    wouldn't rotating them at 5k do the same thing . I'm confused
    Yes I have been regularly rotating tyres around but this time I also flipped the tyre on the rim.
    So white writing on on the inside now instead of outside.
  2. #4402
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    Fitted up some rated recovery points, I was wrapped, I didn't have to remove the alloy bar or anything, I had captive nuts on the passenger side and used the ones that hold the hook on the drivers side.
  3. The Following User Says Thank You to Paule For This Useful Post:
    mudski (2nd December 2014)
  4. #4403
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    After weeks of putting it off, I decided to hook my rear LED work light to the reverse light via a diode so it doesn't back feed to the reverse light when manually switched on via the switch on the centre console.
    Great to finally see where I'm going in reverse.
  5. #4404
    Nov 2010
    Getting a life...
    38 Post(s)
    Fitted new HD king coils and new back brakes cos the old ones were down to metal. ( oops)
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  6. #4405
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    Cut and rolled my guards for an extra 30mm of clearance.
    '96 GQ TD42t
  7. #4406
    334 Post(s)
    Quote Originally Posted by GQJETT View Post
    Good job. What did you use to roll them Jett?
  8. #4407
    Jul 2014
    11 Post(s)
    Cheers mate, I'm really happy with the outcome. I used a heat gun to stop the paint from cracking and just used a small shifter and slowly worked my way around.
    '96 GQ TD42t
  9. The Following 2 Users Say Thank You to Chappy For This Useful Post:
    Dales300exc (6th December 2014), MudRunnerTD (5th December 2014)
  10. #4408
    Expert Agronaught's Avatar
    Sydney, NSW
    Completely rewired my radio setup in a bid to reduce engine noise on HF.
    * ran LL200 in place of the crappy RG58/U coax.
    * Moved the 2m/70cm antenna to the passenger side front bar, UHF CB is on the drivers side.
    * Still using the Alinco DR-635T for UHF CB and Backup 2m/70cm... I really need to replace this unit though.
    Testing a new HF setup:
    * removed the RODA Screw Driver as it sits far too high on the spare tyre bracket and isn't allowed on the front bar.
    Trialling new HF setup:
    * Installed an Optek multi-tap antenna on the rear wheel bracket for HF. (tuned for 20m/14.200MHz)
    * Installed LG-100 automatic antenna tuner on the Optek.
    * Re-ran earthing lines to the tyre bracket, tuner and radio. I really need to buy a few meters of earthing braid :/
    So far the results are promising.
    Waiting on a quote from ministry of the interior for a roof console to fit the radio heads in...
  11. #4409
    brisbane
    In the process of extending the front mounts and its giving me the shits I can only get 40mm out of it so may have to take 10 mm off the extentions grrr
  12. #4410
    Patrol Freak gaddy's Avatar
    redlands
    Swapped out the old sloppy efs 2inch springs , for new 2 inch kings (hardest they do ) gone from been a sloppy whale to a darting dart and picked up 45mm a corner in the process , happy as
