Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Disconnecting the ECU to reset
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I have a 98 Dual Fuel 4.5L which has a problem that I am having trouble getting sorted out.
    If I run on say Gas for 400/500 K when I switch to Petrol it runs really rough. The same if I run on Petrol
    Easy fix just disconnect the Battery for say 15 minutes and all is well.
    I would like to disconnect the ECU only without having to reset all my Radio Stations , time etc.
    Can someone advise me where the Power to the ECU is located.
    This is only a temporary fix as the Wiring for the Gas will be reinstalled when I can afford it.(It is a bloody Snakes Nest)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Disconnecting fuse 49. It's 7.5amp fuse in fuse box under the bonnet. Should reset the ECU.
  3. The Following 3 Users Say Thank You to Yendor For This Useful Post:
    Bob (23rd November 2014), cgm (23rd November 2014), Stropp (25th November 2014)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    I was under the impression the ECU had a internal battery/capacitor Rodney, and after discharging residual current, you still the need to leave it sit (battery disconnected) for up to 3 days to totally clear the memory ?
    Or know someone with a scanner that can clear the memory instantly.
    You mean like a ECU-TALK ?
    Brisbane,QLD
    12 Post(s)
    Maybe, I think you might be able to do it with a ECU talk but ive honestly never used one, regardless id really like to get one for my TB45 anyway just to monitor stuff etc.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Bob's not trying to clear codes. He's just trying to reset the fuel trim when he changes from one type of fuel to the other.
  8. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    04OFF (23rd November 2014), Bob (23rd November 2014)
    Brisbane,QLD
    12 Post(s)
    I.C. so anyway, say if I fit a new o2 sensor for instance, is it true you need to wait a few days to really clear the memory (or use scanner) ?
  10. #8
    Oct 2010
    Pakenham
    47 Post(s)
    Yes that is right.
    Disconnecting the Battery for 15 minutes does the job
    I just want to be able to do it without having to reset the Radio Stations & Time
  11. #9
    Brisbane,QLD
    12 Post(s)
    And why is your location greenbank, did you give the forest the arse ?
  12. #10
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by 04OFF View Post
    I have a Nissan Consult but have never used it .
    Must get off my Arse and set it up
