Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: A/C blower stays on
    Sep 2013
    Brisbane
    Hi Snowy,
    I am interested in a Scan gauge as well for ALL my problems.
    Where from and what model did you get - looking at flea bay there are numerous and they confuse the L out of me.
    Tx,
    Shane
  2. #12
    477 Post(s)
    Quote Originally Posted by Beucam View Post
    Hi Snowy,
    Tx,
    Shane
    What model GU do you have? As the earlier GU's can only use a device called ECU talk. Depending on if you have the OBDII plug or not. But if the Scan Gauge is what your after I think its the Scan Gauge II you want... I'm sure others here will be able to clarify this.
  3. #13
    Sep 2013
    Brisbane
    Hi Mudski,
    I have the 2003, 3.0lt Diesel GU Patrol, and yes it has the OBD2 plug.
    Looking around have seen the ELM327 wifi units which plug into the OBD2 plug, then you down load Torque app onto mobile and you can see and set / reset MIL faults. Any body had any experience with these units.
    I already have a Boost and Pyro gauge, only would like to scan and understand faults.
    Tx,
    SHane
  4. #14
    Advanced Snow Patrol's Avatar
    Jul 2014
    Snowy Mountains NSW
    Gday Beucam
    I got a Scangauge E not the II have a look at www.scangauge.com.au. Then goes to a company call Ample Outdoors in Lithgow NSW. Ordered it Thursday night , in the mailbox Monday morning 130 dolla, cheaper than evilbay. The E gave me the Trip computer I wanted plus will tell you what faults are on the ECU and will reset them for you. It has more than enough features for me. I did think about the II but it came down to $$$$. Have a look at the instruction booklet which you can download from the scan gauge site (http://scangauge.com.au/user-manuals/ ) to see if you want the extra features of the II over the E. Haven't used the other things that you mention. I was more into the ability of the scan gauge to be a trip computer as well once all the ECU setting was done. He he he can tell now if Wifey pulls toooo many revs in the Troll.....
    2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
    1980 MQ Ute (nearly forgot the indestructible farm Ute)
  5. #15
    Hi Mudski,
    Tx,
    SHane
    AFAIK none of the OBD11 tools work on the Di's.
    The Di's have the OBD11 plug but they aren't a fully OBD11 compliant system.
    Scangauge certainly doesn't work.
    I know that ECUtalk does but not sure of any others
    Snow Patrol (20th November 2014)
