Results 11 to 20 of 21
Thread: Fitting all your reccomendations to protect 2011 CRD, definately the right thing?
    With the exhaust are you doing turbo back or just from the Cat back??
  2. #12
    Advanced Snow Patrol's Avatar
    Jul 2014
    Snowy Mountains NSW
    I have just fitted EGR and Dawes set up and gauges to my 08 CRD. Previously fitted catch can and second filter/water trap. Scan gauge will arrive next week to clear the check light The Trol is going well. topping out at 18 psi boost and now will pull up my hill in to gear only dropping 5 kmph and apposed to 10 to 15. Cheaper than chipping and better for the engine. Was a bit fiddly until I got my head around what did what and yes I got a bit lost on the way. This forum has a wealth of information at your disposal so read up and ask questions.
    Footnote: Very happy with the Trol now after a run to Canberra tonight.
    2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
    1980 MQ Ute (nearly forgot the indestructible farm Ute)
  3. The Following 2 Users Say Thank You to Snow Patrol For This Useful Post:
    hybrid (16th November 2014), threedogs (15th November 2014)
  4. #13
    Patrol Freak kevin07's Avatar
    georges hall
    Quote Originally Posted by Snow Patrol View Post
    I have just fitted EGR and Dawes set up and gauges to my 08 CRD. Previously fitted catch can and second filter/water trap. Scan gauge will arrive next week to clear the check light The Trol is going well. topping out at 18 psi boost and now will pull up my hill in to gear only dropping 5 kmph and apposed to 10 to 15. Cheaper than chipping and better for the engine. Was a bit fiddly until I got my head around what did what and yes I got a bit lost on the way. This forum has a wealth of information at your disposal so read up.
    oh jeez wait till you chip it then that will give you the happies
    13 y62 the beast that burbles
  5. #14
    476 Post(s)
    Quote Originally Posted by hybrid View Post
    Thanks for the feedback, noted on the 2.75" beaudesert exhaust, but I have already purchased the redback 3", so hopefully that will be ok. Cheers Renee
    Don't worry. The 3inch will be absolutely fine. 1/4inch difference is sweet f.a. if i owned a crd I would be going 3inch personally.
  7. #15
    Jul 2014
    Hill End NSW
    From the Turbo back Threedogs
  8. #16
    I originally had a 3" exhaust cat back, you could feel the difference big time,
    then I had a DP chip ,straight through Cat and bigger scoop fitted all at once.
    Not a good idea as I couldn't say if there were any huge improvements
    You may want to think about getting your ECU re mapped "2trollfam" just had it done
    and you cant wipe the smile off Sharen's face
  9. #17
    Jul 2014
    Hill End NSW
    Yes Threedogs, I definitely want to look into the ECU re mapping once I save a bit more coin
  10. #18
    Jul 2014
    Hill End NSW
    Well, things are progressing nicely at the mechanic, he pulled off my intercooler and it was full of oil, I'm sooooooo glad I am getting the Catch Can fitted and my car has only 80,000km on it....glad I have taken all the advice you all have provided since joining the forum.
  11. The Following User Says Thank You to hybrid For This Useful Post:
    Hodge (20th November 2014)
  12. #19
    Jul 2014
    Hill End NSW
    Just thought I would update you on how everything went . The car seems to have a much more smoother and immediate response in regards to exceleration, the dawes valve has been currently set to 17 psi which seems to be good. The Scan Guage 2 is a great piece of kit with the various readings it give you and being able to clear the fault code from the egr block. The boost and egt guage also has been a great insight to how the car is going. As for the oil catch can, that really is an essential mod for these vehicles. should of done this stuff sooner.
  13. The Following User Says Thank You to hybrid For This Useful Post:
    Hodge (27th November 2014)
  14. #20
    177 Post(s)
    Good to hear things are going well with the Patrol mate. Dawes and needle need a sweet spot, and once you find it, set it and forget it.
  15. The Following User Says Thank You to Hodge For This Useful Post:
    hybrid (27th November 2014)
