Page 67 of 570 FirstFirst ... 6566676869 ... LastLast
Results 661 to 670 of 5693
  1. #661
    Brought this volt meter but with no backing plate, it will fit great in the centre dash on the LHS
    under a rocker switch I have there, check shop in electronics
    http://www.ebay.com.au/itm/Digital-V...item27e6ca388d
    Edit its to monitor my Aux battery
  2. #662
    84 Post(s)
    Bought a cheap wet/dry shop vac to clean out the underground pipe from the house to the water tank. It worked a treat, after the drain caps were opened and the smelly water level dropped I got 5 x 15 litres of really nasty stuff out. Then went and cleaned all my gutters in a quarter of the time it used to take. I will have to spend some cash to re-plumb the down pipes above ground.
  3. #663
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Oh yeah i got a ryobi one they are fantastic for plumbing related issues. Though never thought about cleaning the gutters with it
    Lucus30's 1999 GU ST TB45E
  4. The Following User Says Thank You to lucus30 For This Useful Post:
    mudnut (14th November 2014)
  5. #664
    84 Post(s)
    I'll make a fitting that easily reaches the gutter under the projecting edge of the tin, and that will make it even quicker. I might also tape the wheels up so the vac doesn't tend to roll off the roof
  6. #665
    .......... TPC's Avatar
    63 Post(s)
    Sounds like a good idea, i hate cleaning gutters and am surrounded by gum tree's.
    What type did you buy & cost?
  7. #666
    Why do you prefer it?
    Have enough trouble with gas and fuel caps on cars lol.
    Anyway it didn't happen. The filler was for petrol. And diesel nozels won't fit in the ports
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yea I know you can fit 2 separate caps in the gq fuel cover but it's tight.
    Much prefer the single cap.
    I've got an LPG and a petrol under the one cap....
    Hello from Under Down Under!
  9. #668
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    I got myself one of these blowers for blowing out my gutters. Works a treat weighs bugger all so it's easy to handle when I'm on the roof and has no cords or hoses to trip on. I already had the batteries so the blower only cost $59.
    http://www.ryobi.com.au/Products/Pow...erVacs/CBL1802
  10. #669
    63 Post(s)
    Quote Originally Posted by firm351 View Post
    I have tried a few times to blow out the leaves but never works for me as the leaves at the bottom are damp.
  11. #670
    84 Post(s)
    Shop Vac super, stainless steel tub. $85 I paid way too much, but I needed it today, so I could get the system ready for the wet weather due this weekend. Also, the vac got rid of most of the algae and moss a blower wouldn't touch. I have seen them advertised for $47 at Godfreys. But there isn't an outlet anywhere near me.
