Page 433 of 1057 FirstFirst ... 431432433434435 ... LastLast
Results 4,321 to 4,330 of 10561
  1. #4321
    North brissy
    Ah I see why I was confused. I have different breather fittings on my diffs. I can't use those fittings.
    Why not? Are you fittings not threaded into the diff housings?
  2. #4322
    brisbane
    I've got the same ones on my car, it's a straight swap for whats on it now but I don't think mine has a right angle goes straight up
    These are the same fittings used for airbags also
  3. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    growler2058 (14th November 2014), mudski (14th November 2014)
  4. #4323
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by megatexture View Post
    I've got the same ones on my car, it's a straight swap for whats on it now but I don't think mine has a right angle goes straight up These are the same fittings used for airbags also
    Straight up for the diffs but 90's for tnsfr and gbox
  5. The Following User Says Thank You to growler2058 For This Useful Post:
  6. #4324
    476 Post(s)
    I will have to take a closer look. To be honest I have never really had a good look at the fitting on the diff. I know the transfer and gearbox are threaded. I had replace the OEM breather hose for longer ones and the barb looked to me it was simply welded onto the diff. As the barb more looks like a thin piece of tube and the breather hose was clamped onto it.
    I need to do mine like Growlers but I will use rubber and one single hose running along the chassis from back (rear diff) to front in the engine bay, and the transfer, gearbox and front diff will simple join into this single hose via T pieces. I did this on my MK and it worked really well.
  7. #4325
    Haven't done it yet but going to move the LED light for my Autron cruise control
    into my pillar pod,easier to see,
    ATM its behind the "T" of the steering wheel and not visable whilst driving
    Also fitting another volt gauge to the centre dash ,left side for my AUX battery
    http://www.ebay.com.au/itm/181455438...84.m1497.l2649
    Will put some pics when done
  8. #4326
    Expert Agronaught's Avatar
    Sydney, NSW
    Ordered the Superior Engineering battery tray for the TB48 as I'm 'fairly' sure I can work out something to relocate the washer bottle even with the LPG.
    The only challenge is I'll need to find somebody to install the weld bolt for me as I've not touched a welder since my teens and I'm not confident enough to do so in the engine bay. (nor for that matter do I own a welder).
    http://www.piranhaoffroad.com.au/lib...ting_guide.pdf
  9. #4327
    Quote Originally Posted by Agronaught View Post
    Billy Bleed is trying to fit a second battery as well in his Dual fuel Patrol.
    Pics would help if you get everything to fit
  10. #4328
    Patrol God Stropp's Avatar
    36 Post(s)
    the arb ones come with a nut on a breakoff rod that you poke into the gaurd through the gap behind the headlight, makes it so easy instead of welding.
  11. #4329
    Sydney, NSW
    I have a nasty dent some sob left in the drivers door that needs to be fixed. I imagine a smash repair place could fix that and weld in a bolt at the same time...
    I'll look into that after my trip in December.
  12. #4330
    Hate to say it but drilled a hole in the centre dash for my AUX battery volt meter,
    Ive also cut the hole for the led switch, so think there goes my no drill policy lol
  13. The Following User Says Thank You to threedogs For This Useful Post:
    Stropp (15th November 2014)
