Results 1 to 10 of 17
Thread: 75ltr reserve tank
    Beginner Mac73's Avatar
    Mar 2014
    Bassendean, WA
    75ltr reserve tank
    Hey all, I have an 03 4.8 dual fuel patrol. the 100ltr gas tank is in place of the original main tank and the standard 35?ltr reserve is still in place. I saw another patrol advertised with 100ltr Gas and 75 ltr reserve but the add was taken down before I could contact to find out where I could get this conversion done. Anyone done this, know where to go to get it done and if it's an easy thing to do or requires significant modification? I can't find any previous threads that talk about this. Thanks all for any comments
    Part time 4wd'er and fisherman, full time worker, why can't it be the other way?
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Sounds like just a standard long range sub tank. You can get them 2nd hand or lra sell them for about $900 bucks I think
    Edit: that's not installed lra will install them but will cost more obviously
    http://www.longrangeautomotive.com.au
    Lucus30's 1999 GU ST TB45E
  3. The Following User Says Thank You to lucus30 For This Useful Post:
    Mac73 (13th November 2014)
    It's pretty much a long range sub tank.
    Lra and brown Davis are the 2 main manufacturers but there are others.
    All you need is the tank I'm sure as the sender unit in your 30ltr tank should bolt in the 75
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Expert Agronaught's Avatar
    Sydney, NSW
    I had the brown Davis sub tank installed in my tb48 at tjm parramatta a couple of months ago.
    Its been a very worthwhile upgrade.
    I also had a number of other items installed at the same time so not sure of the specific labour cost.
    IIRC you would need to change the upper rear RH control arm to a "bent" one to clear the LRA tank as well.
    Sydney, NSW
    There was no need to change the control arm for the brown Davis tank. Note that its 70L replacing the 30L sub tank.
    They say no need for bent upper arm if running lift kits under 2"..
    Once you start running 3"+ kits then you need the modified uppers
    So many variables to it though, some need it some don't... I put one in to be safe, it's not that dear
  11. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (13th November 2014)
  12. #9
    Sydney, NSW
    Fair enough.
    To the OP, adding the long range sub tank has made a big difference to driving the car. I'm no longer concerned about whether the next town had LPG and being able to go 700km without stopping is a luxury i had never enjoyed with this car.
    In my case it was money will spent.
    Note that these tanks use all the available space. Unless you can put the car up on a lift and have the gear to lift the tank and keep it level, pay somebody to do it as there is very little clearance to work with.
    The only down side is the sender reads full for the first 30% of the tank and then drops rapidly. Not an issue once you know about it, disconcerting if you don't.
  13. #10
    Quote Originally Posted by Agronaught View Post
    Fair enough.
    I modified my sender so it reads true right the way through the range
