Vibration started today after installing the catch can.. I dont know how big the turbo is ... where would I look.???
I'm sorry mate but that is too high even without an ic.
If I was in your shoes I would be concerned with the play you said you had in the shaft and running it dry. Have you tuned it?
Again, in your shoes, I would start again.
Find a schematic of the galleries and see if its possible to blow out that gallery without causing further issue and get oil flowing that side of the block because you still have no oil going to alternator yes?
My priority would be to get oil to that side for alternator.
Sort that out and then get a good tune and let an expert advise.
I'm happy to speak to Andy at dieseltec.
You know what....... I am sick of this whole f$Łking thing............ I've had enough.
Try to find a part number on the turbo.
I put a catch can on the ute ages ago and the thing wouldnt idle properly
96 GQ coil/Cab
08 G6eT
311301 can hardly read the numbers and in a shit position
So how well was it running before turbo and intercooler were fitted?
This could be it mate : https://www.dencodiesel.com/genuine-...arger-s2a.html
________________________
______ 2017 D-Max _______
MudRunnerTD (1st November 2014)
