Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Where to run spare wheel light cable.
    Or better, if you can find some hollow mounting bolts to suit the size, would be perfect.
    Attachment 50673
    What a great idea, just need a smear of silastic or similar.
    surprised all the Guru's that have worked on my Patrols never thought of that,
    seeing I have a no drill policy, or did have lol
    Bolt size for the rear wheel bracket is 10mm x 1.25 x 30mm long zinc plated
  2. #12
    Oct 2011
    Essendon
    No drilling here! Ran mine from the engine bay in loom tube, along the chassis rail, around the wheel arch and up between the body and the bumper. A few adhesive backed cable tie mounts on the door and you're done......piece of cake, no holes.
  3. #13
    Advanced bindi's Avatar
    Apr 2014
    Gippsland
    you can drill a small hole behind the wheel bracket on the door and fit a rubber grommet,
    very small hole only 3/16th max from memory
    you don't need to drill metal, just drill a 3/16 (or 4.5mm) hole in the underside of the plastic hinge cover. It pops off easy enough and you won't even see the hole. I threaded my power cable through the mount tube, out the bottom and it it hides behind the wheel, goes through the small hole in the plastic hinge cover, threads through the harness rubber (along with rest of wires) and then just ran the cable under the carpet to the front for power, with a neat little round switch on the middle console. Easy!
    I hate drilling metal, it's just bad!
    2012 GU8 ST CRD Platinum Silver with Tints, Factory Bar, IPFs, Snorkel, UHF, Maxtrax, Rated Recovery points front/rear, In dash Nav, Scangauge2, Ally Roof Rack, OME 2" Lift
