Results 1 to 4 of 4
Thread: Y61 td42
    Sep 2014
    Y61 td42
    Hi guys. What are the torque specs for Y61 TD42 cylinder head? And the valve clearance.. inlet and exhaust. Please help me guys. Many thanks. Tomboy.
    Oct 2014
    Swan Valley
    Torque is in 2 stages. Stage 1= 39-44Nm. Stage 2= 59-64Nm.
    Inlet valve clearances are both same & are 0.030-0.040mm (warm engine)
  3. The Following User Says Thank You to Sharky1 For This Useful Post:
    Jorjina Paul (30th October 2014)
    Sep 2014
    valve clearance. Y61 TD42
    Thanks heaps. what if the engine is cold? will try that and advise. thanks again.
    Quote Originally Posted by Sharky1 View Post
    Your torque specs are wrong mate.
    There are 3 different sequences depending on which td42 you have.
    TD42
    1- 49-59nm
    2- 98-108nm
    TD42T
    1- 39-44nm
    2- 59-64nm
    3- +110 degrees
    TD42Ti
    1- 40-44nm
    2- 59-63nm
    3- +100-120 degrees.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    Dales300exc (30th October 2014)
