Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 79
Thread: Coolant leak CRD 3.0L
  1. #21
    you can see where its coming up from that hose its all discoloured.
    You need to either tighten or replace that clamp,
    blow up the pic you'll see what I mean
  2. #22
    177 Post(s)
    And this morning, not a single drop has leaking since parking the car, 16 hours ago.
    No wonder its doing your head in, very inconsistent
  4. The Following User Says Thank You to threedogs For This Useful Post:
    Hodge (25th October 2014)
  5. #24
    177 Post(s)
    Tell me about it. It's annoying. As per one of my earlier posts, it seems like it's leaking overnight, during warmer weather, as it hasn't leaked at all during winter, and its leaking now with the warm weather coming back and the last time i noticed it was last summer.
    177 Post(s)
    Just had another quick look and no leaks. But realized something else. I don't know why I thought the water pump fits on top of the timing cover, which is why I thought the coolant is leaking from between the timing cover and block. But they are separate items, as per this pic.
    I hope this eliminates the potential to be the timing cover.
    Attachment 50773
  7. The Following User Says Thank You to Hodge For This Useful Post:
    Badball (29th October 2014)
  8. #26
    Advanced batesy's Avatar
    cranbourne vic
    you will see in the pic that Hodge put up right behind the red line a small 2 bolt flange thats for coolant hoses/heater hoses will be coming from their, will only leak when its cold cause it retracts then swells when its hot, will either be the gasket or one of the hose clamps.
  9. The Following 2 Users Say Thank You to batesy For This Useful Post:
    Badball (29th October 2014), Hodge (27th October 2014)
  10. #27
    177 Post(s)
    Quote Originally Posted by batesy View Post
    Thanks mate. It hasn't done it for a few days now, so hard to diagnose further. Will be looking into this area.
    yeah that two bolt flange looked suss too, will have to wait till it warms up eh
  12. #29
    Jan 2013
    Adelaide
    I've got the same issue leaking in the same area. If I top up the coolant bottle it seems to leak until it gets to the low mark then stops and only when it's cold.
    2005 GU IV 3L ST-S Mods: 3in Zorst, chipped, Autron egt, boost and dual voltage gauges, pillar pod, dual battery, IPF round spoties, Nissan alloy Bullbar.
  13. #30
    Jan 2013
    Adelaide
    Hodge, how did you go with the leak? Mine has got worse in the past month, car sat for 2 weeks and emptied the overflow bottle this time.
