Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Coil spacer gorl cost
    Apr 2013
    do you know where abouts you will be most of the time on the gold coast....there is a lot of accessories places there and spread out far and wide...the gold coast is a big area and isn't just surfers paradise...I think you will get the same advise re-springs as opposed to spacers from them also as has been advised to you on here...As mentioned , online with delivery may be a good option if weight is your only concern
    Labrador , ashmore , Nerang , ..good places for dealers...and then Burleigh heads , which is on the other side of surfers....maybe you should just google 4x4 accessorie places and then let your fingers do the walking ...
    http://www.partsman.com.au/skin/fron...ic_slider1.jpg
    I bought my dobinsons springs from him for 300.00 less than dobinsons could supply...was free delivery in qld but I think he charges freight now...maybe you could use part of the lower cost to go towards freight overseas....he is in Glenview qld...0412281319
    the one thing wrong with middle age ...is knowing you will grow out of it !
  2. The Following User Says Thank You to menace 2 For This Useful Post:
    Yan (27th October 2014)
  3. #12
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Quote Originally Posted by Yan View Post
    Attachment 50791
    This is my cars,what kind of Patrol?
    My country the names is just Nissan Patrol y61 3 doors .
    wow! you don't see that too often
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  4. #13
    Feb 2014
    NEW-CALEDONIA
    I just buy this spacers 50mm,but without notice..
    How to recognize the front was the behind?
    And how to fix? On the below or on the above of spring?
  5. #14
    476 Post(s)
    They go above the spring, and by memory the front are a different size to the rear. So you can't get it wrong.
  6. #15
    Feb 2014
    NEW-CALEDONIA
    Thanks ;-)
    But on the upside or downside of spring?
  7. #16
    Feb 2011
    Shed
    45 Post(s)
    Thanks ;-)
    Top.......
  8. The Following User Says Thank You to growler2058 For This Useful Post:
    Yan (16th November 2014)
  9. #17
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Hope this helps
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  10. The Following User Says Thank You to Punderhead For This Useful Post:
