Results 11 to 20 of 28
Thread: TD42 turbo oil drain location
    Ha ha. Very good!!
  2. #12
    Really, would have thought it is above the oil level.
    Mine is near the top of the sump, I'll get a pic in a min.
    You would be surprised. I wasn't joking.
    It works fine either way really. But I have had the sump off a few of these now and the sump alone can just hold 10L to the very brim (have tested with water).
    It is all good the only really thing is that the drain is completely free to flow. So straight down is best .
  3. #13
    Legendary Alitis007's Avatar
    15 Post(s)
    Usually what happens is when the motor is off the oil level is pretty much to the sump gasket but when the motor is running the oil level drops abit. If the oil level is over the drain the oil in the hose could fill up the tube and cause the oil seals in the turbo to fail
  4. #14
    Cheers guys,
    Just assumed the oil level would have been a bit lower but when you think about it 10 litres is a fair bit. Yeah im sure it would work both ways as long as its going straight down. Guess I've just seen them put in without dropping oil or taking off sump.
  5. #15
    15 Post(s)
    Ok just to show some of the science involved with the turbo oil drain, this is the general rule.1413931162493.jpg
    Now acording to my service book there are two types of sumps for the td42 in a gq, one has a 7ltr capacity and the other is 10.5, this one has the 10.5. That capacity is usually to the windage tray or just above so the big ends of the crank don't get a restriction from the oil itself while its rotating.
    This is the full mark on the dipstick which is about 2" from the sump gasket
    This is where the turbo drain will drain from into the sump
    And this is where it will sit inside the sump itself, notice how much higher it is over the windage try
    I'll post up the final result later on
  6. #16
    Aug 2014
    Perth
    10 Post(s)
    on my q the turbo oil return goes in via the motor ill try and get a picture of it
  7. #17
    Quote Originally Posted by gubigfish View Post
    Some had the plug on the block itself.
    Some people also tap into the alternator which I don't think is a good idea.
  8. The Following User Says Thank You to AB For This Useful Post:
    Alitis007 (22nd October 2014)
  9. #18
    15 Post(s)
    Its alot easier for me to replace a sump rather than a block if I stuff up lol
  10. #19
    15 Post(s)
    Tadaaaa!!!
    Looks almost factory!!
  11. The Following 4 Users Say Thank You to Alitis007 For This Useful Post:
    AB (22nd October 2014), Avo (22nd October 2014), Bloodyaussie (22nd October 2014), Family4x4 (22nd October 2014)
  12. #20
    Tadaaaa!!!
    <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=50636"/>
    It's on the wrong side!!!!
    Oh no!!!
  13. The Following 2 Users Say Thank You to AB For This Useful Post:
    Alitis007 (22nd October 2014), Bloodyaussie (22nd October 2014)
