Page 35 of 50 FirstFirst ... 3334353637 ... LastLast
Results 341 to 350 of 498
Thread: Outback Ideas Recovery points
  1. #341
    PM sent on locations for you
  2. #342
    Expert RubberDuckieGQ's Avatar
    Melbourne (inner suburbs)
    Thanks a lot will check it out!
  3. The Following User Says Thank You to RubberDuckieGQ For This Useful Post:
    threedogs (21st October 2014)
  4. #343
    Remember you can only fit one to the drivers side using the existing captive nut on the side of the chassis
    To fit two you'll need to drop the bullbar and fabricate a plate
    to slide up inside the chassis[LHS] with nuts welded on.
    RubberDuckieGQ (22nd October 2014)
  6. #344
    476 Post(s)
    Check my profile and I have a link to a build thread with pics on how to do so...
  8. #345
    Thanks!
    I'll check on my work laptop when i get there - couldn't see a link using the app
  9. #346
    You have a GQ don"t you
  10. #347
    yep 91 GQ
    haha extra text because it said my msg too short to send! :O
  11. #348
    Thought so, Marks instructions will work to a point but he has a GU.
    Easier to trace the holes onto a piece of steel that will slide up the lhs
    Drill and weld some nuts on.
    Your Avatar show no winch some it might be pretty easy
  12. #349
    Patrol Guru Rocket55's Avatar
    Sydney
    My recovery points turned up today. Thanks very much John, awesome service and quality product. Ordered 11pm Tuesday night, waiting on my door step lunch time Thursday in Sydney, can't ask for much more.
    Cheers Rod
    My Build 2005 TD42TI
  13. The Following User Says Thank You to Rocket55 For This Useful Post:
    threedogs (25th October 2014)
  14. #350
    Brisbane
    Finally fitted the recovery points from Outback Ideas. They look great and will do the job. Thanks John for a great product.
  15. The Following User Says Thank You to teach For This Useful Post:
    threedogs (27th October 2014)
