Results 11 to 20 of 22
Thread: The new Project
    Expert kind's Avatar
    Nov 2013
    brisbane
    Your alot smarter then me I wont be able to do that haha
    1996 GQ 2.8TD 3" straight though, draws and oh so much more
  2. #12
    84 Post(s)
    Is your engine, smoking or using oil, gumming up spark plugs or is there a lot of blow-by when running? Or does it only smoke on start up?
  3. #13
    Nov 2013
    brisbane
    Its bit smokey more so on start up as I havnt had the chance to give it a good run with no rego on it its out of tune it smells of fuel when its running to start plugs where a little bit but not to bad im kinda thinking I should just swap the eghust manifold get the roady see how it goes and worst case swap engine after having a good run
  4. #14
    84 Post(s)
    I am thinking give it an oil change with a heavier grade oil and see if the petrol smell returns.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    kind (14th October 2014)
  6. #15
    Nov 2013
    brisbane
    Yeah ill give that a go haha buy the time I fix the dam thing I should just buy a td
  7. #16
    Nov 2013
    brisbane
    So I ended up just swapping the manifolds over found that they had already snapped the bolt off in the block down closest to the firewall and then also one of the threads from inside the block was stripped out so you would just screw the bolt in and out with fingers so now the one closest the fire wall has no bolts in it and it just got a bit of goop im hoping this wont cause me to many dramas?
  8. #17
    84 Post(s)
    You can buy a recoil thread repair kit, or there are mobile thread repairers that can do the job. With the Recoil kit comes a plastic tap tool that stripped out really easily, so I had to use tap wrench.
    With the snapped studs, you can try drilling a hole into them and use Easy Outs.
  9. #18
    Nov 2013
    brisbane
    Yeah I was gonna use the easy outs but I wasnt really to sure if I could get away with not having the bolts in I think ill only have that motor in the car for maybe 6 months before I swap back out
  10. The Following User Says Thank You to kind For This Useful Post:
    mudnut (19th October 2014)
  11. #19
    Feb 2014
    Iceland
    Pictures man, pictures
    2009 ZD30-CRD Patrol ST Wagon. Bullbar, IPF Spotties, Snorkel, BFG285/70R70, 2" OME Lift, Rear Drawers, UHF, Scangauge, VDO Boost and EGT Gauges in an A-Pillar Pod, More bits
  12. #20
    Nov 2013
    brisbane
    So today I got some time and fit the new springs not a bad increase but it makes me need bigger tires 1414917306415.jpg before 1414917336208.jpgafter I forgot to get a pic of before the rear only have the one from top of thread
