Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Rear Drawers final decisions
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    Ive done measurements for my rear drawers to do the cuts but theres a couple of things Id appreciate feedback on before I decide the drawer widths
    1. When allowing measurements for the carpet lets say drawer fronts side by side and using marine carpet, I was going to give them a 4mm gap each all round, having said that if I was to slide the drawers in all the way raw (no carpet) there would be a total of 8mm in between the inner front left and inner front right faces, this seems right to me but interested in your thoughts based on what you expected and what you got or other ways to do it.
    My theory was do a measurement of total thickness on carpet lets say marine carpet is around 5mm and reduce it x 1mm,
    I am undecided as to go Marine, polypropylene (car subwoofer etc), rubberback Indoor which is stain & rot proof but sold in tiles and has an adhesive backing, all available from Bunnings, Marine just seems impossible to do the smaller bends given its strength and thickness.
    2. As I'm using 12mm marine ply I have allowed 12mm recess for the middle upright (front) and left the sides flush with the top and bottom, this should marry up once I cut the facias and also the wing front panels. By doing this the drawer facias will look slightly off centre but I can centralise it by moving the T handles slightly when fitting them or should I just recess the middle and sides and flush it up when doing the side wing fronts??
    3. Has anyone bought the UES Slides, I got a quote on 85kg extended for $66, looked on their website but couldnt find them for specs so a bit worried about the quality, Carac quality was good but $225 a pair, customer service there didnt bother calling me back for a shorter/lighter set (900mm), McNaughtans were fairly helpful until a past customer walked in and the salesman just walked away from me without saying anything. So as far as that goes that's my slide experience, Ive got an Engel 60litre which apparently weighs 33kg empty, Im looking at total max weight of 70kg to be safe. Any thoughts on your slides appreciated
    Dave
    Are you using the Carpet as the draw slide? you'd be better off using Laminex to Laminex or similar to be honest. I think Carpet will be heavy to lug. I have only carpeted the inside surfaces of my drawers to cut down on Rattle.
    When you fit the bottom in dont worry about a rebate just make the drawer shell and cut the base to fit flush within the sides and the fronts so you fix the bottom in from the sides. This is the strongest way by far.
    You could consider lifting the bottom up slightly so the sides are proud and slide on the side edges? Also consider lifting the bottom of a draw up quite a bit and integrate a slide out table in the base of the drawer between the drawer sides. this way you can use the drawer when the slide out table is also in use.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Smoothrun (16th October 2014)
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    I have UES slides, quality is fine and by far the cheapest. From memory I have 1000mm full extension 120kg slides.
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  5. The Following User Says Thank You to Crate For This Useful Post:
    Hay mate. I didn't bother wrapping the doors with carpet, just painted all exposed timber black and carpeted the face.
    A good contact glue and it'll never budge.
    And looks good.
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
  8. #5
    Dec 2012
    Vic Melb
    I thought of that biggqwesty, Im a methodical pr&*k and id like to have a dig at doing the entire front,base and drawer sides (Only what would be seen when opened), Ive seen a few and they look the part. Never done upholstery so I suppose my questions are more related to that effect, but heres an example of what Im hoping to achieve, As mentioned Im even considering doing the draw sides once the slides are attatched, after all it only needs 2 strips of carpet above and below the slides, mind you the painted ones look good too, just personal reference.
  9. #6
    Hi mate, I did the same as Bigwesty, just carpeted the front and cut it flush. Worked well with good adhesive but can understand you wanting it raping it around the edge, it does look good, have seen a few like this. My advice would be to do a couple of dummy pieces once you've got the carpet. I just used the Bunning's auto carpet, which I'm happy with, think marine is probably over the top for inside the car, it is harder to work with.
    I also used the UES slides (120 kg I think) and they are very good, happy with them, easy to install plus the lock out is handy.
    Check out the Full Boar Fourbie drawers, they might be some good inspiration.
  10. The Following User Says Thank You to Rossco For This Useful Post:
  11. #7
    Yea imo scrap doing the insides but wrap the edges.
    Huge cost and a pita if you spill stuff in there it'll be a pain to clean.
    Imo a good enamel paint in gloss. Easy to wipe out.
    But I'd just measure the carpet height and allow that.
    So say 5mm pile height allow a 8-10mm gap between the faces..
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
  13. #8
    Dec 2012
    Vic Melb
    Thanks Rossco, I only wanted to use marine because I know how durable it is (had 5 boats), only prob is yep! flexibility, the auto carpet is on my list and has a bit more flex, IMO I recon it looks better too, it matches the car interior in appearance and color also (black), I am gunna use the Kwik Grip Gel for sticking it on as its a good product and price, considering the spray on but never used it.
    I just checked out the UES Slides and it seems IRS in WA and QLD sell an identical set, I typed in the model number I was given off the UES website and got the IRS product which gave an excellent overview including a you tube video to look at the slides in packaged,opened,extended,locked etc. well worth a look if anyones considering looking into 125KG fully extended 1800mm in total slides, UES had them for $66 non locking and $75 locking 900mm closed 1800mm extended. I'll head down there over the next week or so and have a physical look at them.
    The Full Boar Drawers are well worth a look at, Ive been on the website this week and may even give them a call, the prices he has on ebay are for a lower end setup (not quality just application) and Im looking for something which requires a modification or 2, If they come to the party Id be happy to purchase a locally sourced product, (with respect to other interstate Genuine Australian Manufacturers).
    Cheers and Thanks
  14. #9
    Dec 2012
    Vic Melb
    Thanks BigWesty, its what I was thinking, just needed some experienced members to give me heads up, cheers
  15. #10
    Dec 2012
    Vic Melb
    Thanks MR, Ive been strongly considering this, Im trying to come up with a way to use it both as you mentioned, also Id like to remove it and have it mount on my rear tyre to be used in conjuction with a side awning, what how where when and why is to be considered in line with many other factors before I begin. Cheers
