Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 57
Thread: Squealing belt and/or pulley
  1. #31
    Legendary happygu's Avatar
    Mine has been doing the same thing, only when cold or when I go through deep water / river crossing .......
    Now it is warming up - all quiet again
    Mic
  2. #32
    177 Post(s)
    Sprayed a bit of water on the belt this morning and for a second it went away, then became very high pitched , and eventually went away.
    476 Post(s)
    Take the belt off and check the idler pulley wheel bearing, see if its got any play. Check the alternator pulley too. Also the shocker mounts might have worn out enough for movement to make the belt loose enough. But I doubt it. My guess its just the belt or the shocker on the tensioner has lost its mojo. But since this only happened from the last trip. It will be the belt I reckon. You should keep a spare belt with you anyway mate. As if that breaks, you won't be going anywhere.
  4. #34
    Quote Originally Posted by roofy View Post
    here ya go john ntn bearing number wc87503 oe artical
    i orded mine through bj bearings in warragul about 2years ago
    thanks mate will chase one up,
  5. #35
    T50 is the size of the Torx bit you need. Good luck in finding the bearing. I found either the same as the aftermarket bearing then, 4mm wider. The right bearing, a guy at SKF in Campbellfield found the part number for me but no bearing supplier in the country had one. Not just SKF, but, CBC etc etc. I did the rounds about 12 months ago. I have all the part number for this somewhere...
    T50 it is thanks Mark
  6. The Following User Says Thank You to threedogs For This Useful Post:
    mudski (16th October 2014)
  7. #36
    177 Post(s)
    I will buy a new one today.
    If it let's go... Apart from being stranded , can it cause any damage like throw something out of sync ???
    Sent from my S4 using Forum Runner
    With mine, I had the dealer look at it at the last service, and they told me the tensioner was fine, but I had to bring it back and leave it overnight for them to look at it first up in the morning, even though I had a clear video of the noise, which sounds exactly like belt noise to me.
    I never got around to taking it back to them and leaving it overnight, as that is the biggest pain in the arse for me ..... I have a spare genuine Nissan belt and tensioner anyway in the back. I was going to change the belt to confirm that this was the noise but now it is too late with the weather warmed up ..... I'll just leave it till next year ( or the next service where they tell me my tensioner is shagged, but it is now out of warranty ... )
    Mic
  9. The Following User Says Thank You to happygu For This Useful Post:
    Hodge (16th October 2014)
  10. #38
    Expert Ronin's Avatar
    Brissy
    Quote Originally Posted by happygu View Post
    Mic
    I had the exact same issue, on a cold start there was a squeaking noise and it would go away as the engine warmed up. Spoke to the dealer and they asked for the Patrol to be left with them.
    They changed the belt and the noise has gone away.
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  11. #39
    177 Post(s)
    Well, replaced the tensioner today, after it was left over night and they are confident thats what it was when she started this morning. Will see what happens tomorrow morning.
    Attachment 51321
    brisbane
    Got miNe replaced today with a service and it was shagged
  13. The Following User Says Thank You to megatexture For This Useful Post:
    Hodge (6th November 2014)
