Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Squealing belt and/or pulley
    177 Post(s)
    OK tested it out this morning, and I also recorded it. You can hear that annoying squeal in the video below at around 15-16 second mark, that instantly goes away and the revs ever so slightly change up or down I cannot tell which way...
    I should also mention that this click or whatever has always happened not long after I started the car, but this time it also includes this squeal after wombat. It only happens when it's cold, so tomorrow morning I will put water or belt grip on it, to test what that does... But I suspect something else that engages or disengages. It can only be the alternator (clutch) or the fan ????
    476 Post(s)
    I brought an after market one and the chrome pulley is held on with a torq bit screw,
    I want to remove the pulley and replace the bearing with a known brand bearing
    T50 is the size of the Torx bit you need. Good luck in finding the bearing. I found either the same as the aftermarket bearing then, 4mm wider. The right bearing, a guy at SKF in Campbellfield found the part number for me but no bearing supplier in the country had one. Not just SKF, but, CBC etc etc. I did the rounds about 12 months ago. I have all the part number for this somewhere...
    threedogs (16th October 2014)
  4. #23
    177 Post(s)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by hodge View Post
    ok tested it out this morning, and i also recorded it. You can hear that annoying squeal in the video below at around 15-16 second mark, that instantly goes away and the revs ever so slightly change up or down i cannot tell which way...
    I should also mention that this click or whatever has always happened not long after i started the car, but this time it also includes this squeal after wombat. It only happens when it's cold, so tomorrow morning i will put water or belt grip on it, to test what that does... But i suspect something else that engages or disengages. It can only be the alternator (clutch) or the fan ????
    sounds like the bearing starting to go
  6. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Hodge (15th October 2014)
  7. #25
    177 Post(s)
    Quote Originally Posted by roofy View Post
    Definitely. Buy which bearing though... It's one of those start replacing each, elimination process.
    476 Post(s)
    That click you hear. Try this. See how long it takes from turning the key and starting to the click. Then time it again but just go to ignition and don't start the car. That click I reckon is the glow plug relay and it's just a coincidence about the belt noise stopping at the click.
  10. #27
    TRAFALGAR VIC
    35 Post(s)
    i brought an after market one and the chrome pulley is held on with a torq bit screw,
    i want to remove the pulley and replace the bearing with a known brand bearing
    here ya go john ntn bearing number wc87503 oe artical
    i orded mine through bj bearings in warragul about 2years ago
  11. The Following User Says Thank You to Sir Roofy For This Useful Post:
  12. #28
    177 Post(s)
    Will do mate. I'll time it tomorrow and see what happens.
    But it's just weird... If it were the belt, you'd think that noise would gradually go away, fading away as the belt warms up, stretches or whatever... But noise is consistent, from the moment the engine turns, and then in an instant, disappears.
    TRAFALGAR VIC
    35 Post(s)
    definitely. Buy which bearing though... It's one of those start replacing each, elimination process.
    my guess is the belt tensioner
  14. The Following User Says Thank You to Sir Roofy For This Useful Post:
  15. #30
    TRAFALGAR VIC
    35 Post(s)
    that click you hear. Try this. See how long it takes from turning the key and starting to the click. Then time it again but just go to ignition and don't start the car. That click i reckon is the glow plug relay and it's just a coincidence about the belt noise stopping at the click.
    i was thinking the same as the glow plugs shut down after 2nd glow
    send yendor a pm he,s the man for this
