Results 1 to 6 of 6
Thread: drivers side electric window
    Aug 2014
    Perth
    10 Post(s)
    Hi all the GQ drivers window stopped working. when you press the button to wind the window down nothing happens and then if you press up you can hear the motor continually turning until you switch the car off. I tested the motor by disconnecting the passenger one and replacing it with the drivers one and its working fine. The only thing I have noticed is the gear allows you to turn it on the drivers and not on the passenger.
    Does this sound like I'm up for an actuator or a replacement amp module?
    Apr 2013
    the gear inside the winding mechanism has stripped mate....(not the plastic gear for the motor )..check by using a hand winder on it from anything and if it will turn and the window doesn't move then that is it....I took the winding mechanism off the slides ...drilled a hole through it in the round section where the gear is inside ....the hole I drilled was the same size as a 2" nail...I didn't drill it right through....I cut the nail off to the same length as the hole and hammered it in with a firm fit as a codder pin and also using super glue....I did this to two of them .....all assuming it is the internal gear in the winding mechanism that grabs the teeth on the arched arm ....
    the one thing wrong with middle age ...is knowing you will grow out of it !
  3. The Following 2 Users Say Thank You to menace 2 For This Useful Post:
    gubigfish (11th October 2014), Stropp (11th October 2014)
    Patrol Freak kevin07's Avatar
    georges hall
    I had this problem I pulled apart the winder where the 3 screws are and tightened everything up with washers to stop the free play all good now.
    13 y62 the beast that burbles
  5. The Following User Says Thank You to kevin07 For This Useful Post:
    Aug 2014
    Perth
    10 Post(s)
    ok anyone got any ideas how I can get the window actuator out to see if I can fix it or if it needs a new one? Also if I take it out how much fucking around is it going to be to put it back in?
    georges hall
    it will come out easy I think its in your electric winder though
    Aug 2014
    Perth
    10 Post(s)
    Quote Originally Posted by kevin07 View Post
    Motor is fine, tried it with the passenger side and it had no issues winding down and up
