Page 56 of 81 FirstFirst ... 5455565758 ... LastLast
Results 551 to 560 of 807
Thread: EFI to Diesel conversion.
  1. #551
    They make power to 4000rpm, dont be shy. Clean the cobwebs out
    Agreed, happily sit on 3k as well BA.
    Although you have issues with the pump I would be one happy camper with buying that engine unseen mate.
  2. #552
    Thomastown, Melbourne
    6 Post(s)
    Edit.
    Keep the pump you have now until you can afford a turbo, then spend money on it
    Really ... I was tempted to give it a good go and thought to myself it probably needs a good run... I still need to sort a few things first.
    The speedo is not working and need to trouble shoot that, I had to use a speedo app while I was out before.
    My tyres are out of balance also so that does not help.
    Early days I guess and clearing my head for the last 10 days has helped.
  3. #553
    North brissy
    yep there is a reason why there is a red bit on the tacho.
  4. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (7th October 2014), Bloodyaussie (7th October 2014), growler2058 (7th October 2014)
  5. #554
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Having a quick catch up on your thread last night and again tonight I think it sounds pretty positive BA. Not quite to the end yet, but the good compression across all cylinders is a big win compared to the scare earlier. At least now you know you can slowly get there as you get the $$$ together. If compression was stuffed that was going to be a killer.
    Thanks, Cameron
    No Patrol now - Just good memories!
  6. The Following User Says Thank You to cgm For This Useful Post:
  7. #555
    6 Post(s)
    Ha ha ha ha ha ha................Gold !!!!!!!!!!!
    So if it does not want to pull all the way then I need to park it and get the pump sorted.
  8. #556
    North brissy
    Quote Originally Posted by Bloodyaussie View Post
    In a race application the needle will go into that red part .
    What does it pull to? If it still pulls ok and economy and smoke aren't excessive then there is no reason to park it.
  9. #557
    334 Post(s)
    Did you get the Dyno sheet from JPC? They would show your power curve through to 4,000 I would have thought. When I first did the Dyno I found another 1000 revs for sure mate, until then I'd never really gone past 3000 but it bogeys to 4k now.
    I keep forgetting you don't have a turbo yet, I would run that pump until your cashed then do the turbo and pump build at the same time. You can spend a bit or a Sh1t load though.
    Chasing 120rwkw is realistic and reasonably priced, chasing 150rwkw is significantly more, chasing 180 to 200rwkw is a whole lot more money.
    Invisible Ink.
  10. #558
    6 Post(s)
    I will go out tomorrow and see what it will do... I really did just putt around and only went on the freeway along to the first exit so did not go far.
    Maybe I will take the boy for a decent trip up the freeway for 30 min or so... hopefully I dont need rescuing ..he he !!!
  11. #559
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    Well by the sounds of it, it is good news man. Glad to hear. If you are going for a burn up the freeway for 30 min and need rescuing ( not that you will) give me a buzz I am home all morn once I have dropped the kids off.
    Sent from me using Forum Runner
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  12. The Following User Says Thank You to krbrooking For This Useful Post:
  13. #560
    Quote Originally Posted by krbrooking View Post
    Well by the sounds of it, it is good news man. Glad to hear. If you are going for a burn up the freeway for 30 min and need rescuing ( not that you will) give me a buzz I am home all morn once I have dropped the kids off. Can stop in for a coffee if ta want.
