Page 11 of 28 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 277
Thread: Growlers' GU DX
  1. #101
    its for his vibrator
  2. The Following User Says Thank You to Clunk For This Useful Post:
    growler2058 (24th September 2014)
  3. #102
    You sure it's not a PROJECTA??
    its actually ProjectA, but no experience with them,
    Most use either Piranha or Redarc
    http://www.ebay.com.au/itm/PROJECTA-...item33871b4946
    Is this the one
  4. #103
    SUCH IS LIFE Maxhead's Avatar
    ACT
    It is? This is their logo
    ________________________
    ______ 2017 D-Max _______
  5. #104
    They may have changed their branding but when first on the market it was ProjectA.
    but most call it Projecta. No big deal though lol Ring them lol
    potatoes potartoes
  6. #105
    potatoes potartoes
    No, it's more like POTATOES PotatoeS
    Who gives a crap!!!!!!!!!!!!!
  7. The Following User Says Thank You to Winnie For This Useful Post:
    katwoman (24th September 2014)
  8. #106
    Feb 2011
    Shed
    45 Post(s)
    The mystery button. Any ideas? Yes I've pushed it
    The Projecta 100amp
    Annd what's this for???
  9. #107
    Trace the wires from the switch and see where they go? Maybe the battery isolator override? Hear any relays when it is switched?
    I think the 2nd switch is the engine idle up switch used to warm the motor up quicker? Have you pressed that one?
    This GU thing is too complicated for your old brain!
  10. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (24th September 2014)
  11. #108
    .......... TPC's Avatar
    63 Post(s)
    As Winnie said, the switch on the right is a fast idle switch, it is disabled as soon as you accelerate.
    The switch under the fuel cap release could be for anything, usually a blank hole there.
  12. #109
    Yeah I reckon it might be to link batteries. What Winnie said trace the wires should solve it.
    Nice truck good luck with it sure it will progress nicely. Shame I never got to meet old g
  13. The Following User Says Thank You to Rossco For This Useful Post:
  14. #110
    ACT
    Agree with shitbag, it's the override switch and the idle up switch
    The idle up will disengage as soon as you put it into gear and then stop working when temp is up
    Manual override(this is from their website, I'm not that cleva)
    Manual override is activated by connecting the override
    wire to 12V DC. This bypasses the automatic voltage sensor
    allowing the relay to be engaged below the set voltages.
