Results 11 to 20 of 23
Thread: Wiring Fridge,Compressor,Fusebank
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    Before I add notes and for those who have replied, I say thankyou, but Please bare with me guys Im fairly new at forums, including replying with quotes adding pics and somehow just read all the input on this including Cuppa's and ET's which i didnt get a thread reply message for, others I did read yesterday, Not meaning to sound rude for late replies but between getting notifications whilst im at work (driving),using my secondary crappy phone whilst No1 is being repaired over next 2 weeks im limited for comms. Not to mention I sleep during the days and start work at 5pm and home 6-7am, hence this early reply now.
  2. The Following User Says Thank You to Smoothrun For This Useful Post:
    MudRunnerTD (22nd September 2014)
  3. #12
    Dec 2012
    Vic Melb
    I would run it straight to the back and install your sub board in the rear. Put a fusable link under the bonnet for the wire running to the back. I have run a single 35mm2 wire to the rear as the supply as there is then no voltage drop and I can run whatever I like. Including the option to wire up an Anderson plug at the tow bar for the camper trailer charge.
    Swap your fridge plug for an Anderson Plug.
    I have a fridge in the back permanently. I have a second Anderson plug outlet for a second fridge when touring if I want it.
    I have an Anderson plug to hook up a 1500w pure sine wave inverter in the rear too.
    I have an ARB hi output compressor permanently wired.
    I have running water via a 12v pump at the rear.
    I have a rear work light
    I have multiple led lights to the rear.
    I also have multiple charging point a at the back for when at camp to run lead lights or to charge the iPad etc.
    The sub board works great and there is no voltage drop.
    Earth you second battery to your motor and your chassis. Earth your sub board to the chassis.
    That's what I have done and works a great.
    Thanks mudrunner, I did contemplate 2B&S and was actually thinking about getting Welder cable from BOC or CIG for the job, like I said im only limited in Autoelec stuff, mainly car audio gear over the years and this stuff is leaps and bounds ahead of me, so this is where ill start getting lost,
    Taking into consideration that everything will be fused at the rear of the car which is what I want I was thinking about what to have under the bonnet, my thoughts were to have an isolator switch for emergency, welding, works etc, then I got to thinking, would a say 50A fuse be ok under the bonnet which is something I could keep above the rear 40A and if faults are found under 50A then the source would be found at the rear, would that be ok to do, then Id put the isolator down the back next to everything before the sub board of course. Id be interested to know how you went about it, also if you could give me any advice on a decet sub board id appreciate it.
    Cheers Smooth
  4. #13
    Dec 2012
    Vic Melb
    The fuse blocks I used are from Jaycar and they had a decent sized stud for the power input. I simply used battery lugs crimped onto the 6 B&S and bolted them to the fuse block terminal.
    Attachment 49504
    Ill have to head down to jaycar and have another look, either they were out of stock or i was looking in the wrong place, the ones i saw were smaller, how do those style handle the corrigations and how do the terminals hold up being exposed Sooty?
    Smooth
  5. #14
    Dec 2012
    Vic Melb
    Do as you’ve suggested, plus add MR’s suggestion for an Anderson plug on fridge.
    I’m not sure what current your compressor draws, but if it’s anywhere close to 40 amps, then putting a higher amp fuse at the battery would be worthwhile otherwise you run the possibility of blowing it if you ever run something else at the same time as the compressor.
    Unless you have a very small & super efficient fridge it will most likely draw more than you suggest. Your figures look more like ‘average’ draw to me (i.e. taking into account the off cycle, & averaging total use throughout the 24 hour period & dividing by 24. I’d guess when running 3.5amps to 5 amps would be more likely. A 7.5 amp fuse should suffice. If it blows on start up, put a 10 amp one in.
    Something worth considering is to use circuit breakers rather than fuses. Over time & in mobile situations like ours where vibration is part of the equation they are safer & more reliable. Lots of instances of blade fuses becoming high resistance over time & melting, with fire being a potential result. I don’t know why but this seems more common in the multi fuse blocks. Loads of people will tell you that they have used these multi fuse blocks without problem.... and they have, but I have seen & heard of plenty occasions where catastrophe or near catastrophe has occurred. (From melted fuses & wire insulation to complete loss of vehicle). Circuit breakers come in a number of ‘flavours’. I like the type that are switched, as they double as circuit protection & on/off switches, & don’t require spare fuses to be carried.
    If you want to stick with fuses then this sort of ‘resettable fuse’ gives a little extra convenience. They are available in a variety of amperage values.
    http://www.ebay.com.au/itm/NARVA-557...item33925c8f3c
    I was thinking id only need a 5A to 10A fuse for the fridge Cuppa, appreciate you clarifying that up for me. For the record ive got an Engel mt60f rated @ 4.2A, i shoulda worked out the formula for power usage but between doin all this research and reading up on everything i need to do to my new rig ive had to lapse out on some details which i will get around too,
    As far as circuit breakers go im not new to the idea of it and definitely the way id prefer to do things, but like i mentioned my experience is not ready to start playing with them yet and i dont know anyone who has, so im thinking about finding the safest most sturdiest fuse bank i can and go with that for now and ill do some homework on the breakers a little later, and thanks for the link re the resetable fuses,
    One question if i may, whats the difference between a curcuit breaker and a resetable fuse, more power options or u can link 2 or 3 curcuits to one side and run those inline, might sound stupid but first thing that comes to mind if thats what they do/are for
    Appreciated
    Smooth
  6. #15
    Glad I read this, I had no idea the Engel plug unscrewed to reveal two pins, I have two anderson plugs here I was going to use for the fridge but I'll use those for something else and get myself an Engel surface socket.
  7. #16
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Can someone post a pic or a link to the Engel plug "exposed"? Want to be clear - might have missed this in the past too.
    Thanks, Cameron
    No Patrol now - Just good memories!
  8. #17
    Here it is CGM
  9. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    cgm (22nd September 2014), Smoothrun (23rd September 2014)
  10. #18
    Jul 2012
    Ballarat
    Here it is CGM
    That's cool. I'd never noticed before that you could actually screw them in.
    Thanks to ET for pointing it out. Definitely another option for various things, and it can't rattle out.
    Thanks, Cameron
  11. #19
    Quote Originally Posted by cgm View Post
    My pleasure.
    You can source the sockets for your vehicle from a few places.
    Baintech have a couple of variations but are a tad expensive at $30 and up
    OR
    You can Google around and see what you can get... search for "posi-fit" usually finds some
    OR
    Narva Part number is 81132 and single outlets are around $15 to $20 on Ebay
    Plugs are also available for converting other brand fridges or accessories and Narva Part number is 82109
    Usually the cheapest option is Ebay (Narva or Baintech) however that is without the Ciggy Plug nose
  12. The Following User Says Thank You to the evil twin For This Useful Post:
  13. #20
    178 Post(s)
    Quote Originally Posted by Smoothrun View Post
    A re-settable blade fuse is a small circuit breaker designed to fit into blade fuse holder. It has the advantage of not needing to carry spare fuses to replace, but compared to other circuit breakers where wire connections are usually made with a screw type connection, the re-settable fuse still has the blade type connection of fuses. It is the blades & the holders which over time can oxidise causing them to become high resistance & to get hot without the fuse blowing.
    To be honest I’m not sure what a resettable fuse would do in this situation, but I’m guessing it would be more likely to break the circuit than a fuse would. I wonder if anyone else might comment to clarify?
  14. The Following User Says Thank You to Cuppa For This Useful Post:
