Page 42 of 81 FirstFirst ... 4041424344 ... LastLast
Results 411 to 420 of 807
Thread: EFI to Diesel conversion.
  1. #411
    Sounds like things are mov'n along.
    Im around most of the day, give us a buzz if you need a hand.
  2. #412
    Thomastown, Melbourne
    6 Post(s)
    All good mate... just at that pottering point..
    Yes and Darren for the lovely coffee..lol !!!!!!!!
    Daz gave me an airbox but I still needed another part between the airbox and pre cleaner so bidded on one last night that was mint and came with a K&N filter and got it for $20 and to top it off it was just down the road..
    Also the bloke and his dad had the most mint pair of GQ utes and spent an hour chatting and checking out the vacuum lines and so on.... taking another break now to do stuff with the family.
    When I get back I need to see if the bonnet will fit with a couple of mods I have done??
  3. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Family4x4 (31st August 2014)
  4. #413
    Legendary Alitis007's Avatar
    15 Post(s)
    I've got your bonnet cupcake, or do you have a spare ??
  5. #414
    15 Post(s)
    Hey i need you to bring me some diesel to flush out your tank and also you going to run the diesel tank pick up or planning on running a low pressure high volume lift pump?? It might be worth your while to run one to help keep a constant flow to the injector pump
  6. #415
    North brissy
    Quote Originally Posted by Alitis007 View Post
    I would also suggest doing the lift pump if funds and time permit. It helps with the pump supply which can make a difference and also makes servicng easier
  7. #416
    6 Post(s)
    Like this or do I just shut up and leave it to you George???
    http://www.ebay.com.au/itm/12-volt-U...3b4d74d&_uhb=1
  8. #417
    North brissy
    Carter 4600hp mate.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    Bloodyaussie (31st August 2014)
  10. #418
    6 Post(s)
    Carter 4600hp mate.
    Oh ok..... Just looked it up on ebay... this seem about right, there were plenty more for much more?
    http://www.ebay.com.au/itm/CARTER-CO...f4cc37c&_uhb=1
  11. #419
    North brissy
    Yep one of those. Im pretty sure rocket sell them too
  12. #420
    6 Post(s)
    Who is Rocket...?
    I am so out of the loop.
