Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: GU 3.0 water pump
    Unafordable
    4 Post(s)
    That is indeed an ugley fix as the engine needs to be removed for that job. The leak is probably between sandwich plate and the block. Good luck
  2. The Following User Says Thank You to Rumcajs For This Useful Post:
    Dr Gary (3rd September 2014)
  3. #12
    Gold Coast
    Finally have the Patrol back: issue was a leak in the steel gasket between the front engine cover and the block. It is not possible to remove the cover unless you drop the sump. It is not possible to drop the sump unless you separate the engine from the gearbox (two studs in back of the sump inside the bell housing).
    Finally just removed the engine and worked on it on the bench. Too much stuff in the timing gears etc to work in the engine bay.
    We did discover serious coking in the inlet manifold, so now I am fitting a Provent. Dual Dawes with electric solenoid will follow.
    What a nightmare !!!!
  4. #13
    Gold Coast
    Quote Originally Posted by Rumcajs View Post
    Exactly correct--see my reply today.
