Page 20 of 66 FirstFirst ... 1819202122 ... LastLast
Results 191 to 200 of 660
Thread: The Hunters Thread...
  1. #191
    brisbane
    Good to hear there was no issue with the 22 after last weekend
  2. #192
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Would have been a faulty round I put 30 through it today with out cleaning it even tried rapid fire groups of 5 and not one issue with it.
    Such is the rule of honour.
  3. The Following User Says Thank You to macca86 For This Useful Post:
    megatexture (10th August 2014)
  4. #193
    84 Post(s)
    G'day all. I haven't owned rifles for over a decade. I met up with an old mate who has recently got his gun licence and is in the market for a rifle for rabbit, fox and vermin in general. He was asking my advice on which rifle is better and /or more economical to run. A .22 magnum or a hmr .17, 9, (if I remember correctly). I liked the 22, and have never used the.17. I told him about you blokes and that I would ask you for your thoughts on which is the better choice. Thanks in advance. Fire away...
  5. #194
    love my .17hmr over my 22 anyday,in saying that I have a model 1a Lithgow single shot open sites..shoots straight as a dye(or whatever)my .17 will hit anything within 100mtrs,good for foxes cats and bunny's..have hit shags at over 200mtrs but that's just arse as there good for about 150 meters..i have a Marlin.17HMR but I have heard the savage mark2 with an ......acu-trigger?is the better option.
  6. The Following User Says Thank You to Avo For This Useful Post:
    mudnut (16th August 2014)
  7. #195
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by macca86 View Post
    I'm happy with my shooting now ready to hunt
    Pic 1 5 shots of 22/250 55gn @100m
    Pic 2 3 shots of 7mm rem mag 150gn @ 100m
    Pic 3 5 shots of 22 42gn @ 50m
    The 22 does shoot better but the wind took its toll on it today
    The 7mm is a bit high on purpose as at 200m it should be the same distance below the centre
    As a size reference the centre dot to the second ring is 25mm
    Those 22/250 shots look like you are squeezing the trigger at different breaths. Do you squeeze at exhale?
    1999 GU 4500 dual fuel
    Il dado è tratto
  8. #196
    Quote Originally Posted by NP99 View Post
    don't ask personal questions.
  9. #197
    Patrol Guru Family4x4's Avatar
    Jan 2014
    Victoria
    That's something my father in law would pick up on. He is ex military and the best shot I know, he is scarily good and fast.
    In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
    Theodore Roosevelt
  10. #198
    Feb 2013
    Broadford VIC
    Quote Originally Posted by Family4x4 View Post
    after a while you see breathing patterns in group shots
    BTW Macca, those groups are pretty good
    Il dado è tratto
  11. #199
    Jan 2014
    Victoria
    After most of my shots I like to check for no signs of breathing patterns.
    Theodore Roosevelt
  12. The Following User Says Thank You to Family4x4 For This Useful Post:
    NP99 (16th August 2014)
  13. #200
    Feb 2013
    Broadford VIC
    I'm sure you guys can group and zero and by no means is the following meant to be showing off or being a smart alec. For those that don't know I have made a drawing and try to explain. It's a rough and ready way.
    Decide at what range you want to be zeroed at. Remember if you are spot on at 100 metres you will be significantly higher or lower at other range distances due to trajectory.
    Start by firing two warmer rounds down the barrel.
    Now, using the same point of aim, doesn't matter where on the target as long as it's the same point of aim (poa), in this example the black dot on the lower part of the orange dot. Fire 5 rounds at the poa.
    With some luck the 5 shot group should be pretty tight. If not keep trying, you don't need a wild shot high, low etc to stuff the grouping.
    Once comfortable with your group sizing, you need to determine your mean point of impact (mpoi), to do this draw a verticle line down your left and right shots and a horizontal line over your high and low shots. Draw a X through the box created as in my red lines and where the cross middle is , is called the mpoi. The mpoi needs to be adjusted across to your poa. This might be 100mm right and 25mm low.
    Your open sight or scope adjustments tell you 1 click equals 12mm for example so work out how many clicks to adjust as needed.
    Fire another 5 round group and if all went well it should be firing your mpoi group over the poa.
    This is the simply version and does not take into account weather or firers human factors of breathing, squeeze technique etc etc.
    Hope this helps.....it's been a while, so if I forgot something, apologies.
    Il dado è tratto
  14. The Following 5 Users Say Thank You to NP99 For This Useful Post:
    clawrence (15th September 2014), Family4x4 (16th August 2014), growler2058 (16th August 2014), mudnut (16th August 2014), MudRunnerTD (16th August 2014)
