Page 21 of 35 FirstFirst ... 1920212223 ... LastLast
Results 201 to 210 of 343
Thread: Installing WRX front mount intercooler with 3" pipe to GQ
  1. #201
    So bloody close but no cigar!!!
    I want the ic as much as possible behind the grill regardless of what bar goes on.
    Took off thermo and support rail, relocated horn, moved ac piping, that piping was easy to relocate.
    Pushed the condenser back and I am about 210mm now...10mm off this bloody highmount fitting on the bar.
    Had to re do the piping on the cold side because its so far back now so next week ill mount the ic again and have a look.
    So close!!!
  2. #202
    Oct 2011
    Essendon
    To clear up the situation with Andy's winch bar, his is the factory Nissan winch bar for a GQ, made by ARB.
    It is different to the ARB winch bar variants, one of which was designed to be able to take a high mount, the other only a low mount.
    Sent from my iPhone using Forum Runner
  3. The Following User Says Thank You to Drewboyaus For This Useful Post:
    AB (10th August 2014)
  4. #203
    Remember AB 220mm is the measurement but you really need a little bit of clearance mate
  5. #204
    Yeah it's not happening on this bar mate, I just wanted to move it back as much as possible for the grille and inconspicuousness....lol
  6. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (10th August 2014)
  7. #205
    Double checking measurements tonight you really couldn't even fit a highmount to this bar regardless of the ic without completely removing the grille.
  8. #206
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Why can't you make brackets to mount the bulbar a little bit further forward? To give you some more room?
    Such is the rule of honour.
  9. #207
    Thomastown, Melbourne
    6 Post(s)
    I'll swap you my bar plus your spare tyre for your bar.....
  10. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    MudRunnerTD (11th August 2014)
  11. #208
    Are you sure???
  12. #209
    Oct 2011
    Essendon
    I'm confused.....
  13. #210
    6 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    I'm confused.....
    Thats not hard
