Results 1 to 10 of 19
Thread: What do you carry in your First Aid Kit?
    Patrol Freak Gecko17's Avatar
    Mar 2013
    Hey all,
    I was just reading 3dogs post about what everyone carries in their 4wd's and was pleasantly surprised to see that nearly everyone carries a first aid kit.
    This got me to wondering what everyone puts in their first aid kits. For me, as a paramedic, I carry my trauma kit and O2 pack with resus gear as, if I come across an accident, I don't have a choice but have to provide treatment. (unless declined or they are already being treated by someone of higher quals.)
    So, what does everyone carry in their first aid kits?
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
    Advanced briscott's Avatar
    Jul 2014
    Amongst the other stuff, I have 2 first aid kits, and the biggest lump of that is in bandages and crepe. That aside, I carry Burn Cream, Antiseptic, Anti spew/poo tablets, a range of pain killers, ventolin and a sharp knife.
    I'm about to do a double crossing of the Simmo (2 weeks ), what would you suggest I add?
    Great dealings with: Rex;
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    To be honest I have no idea its an off the shelf st johns one. I've only ever used the band aids out of it
    Lucus30's 1999 GU ST TB45E
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    A lot of stuff, have only used it at work due to the lack of supplys there
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    My most useful item is a pressure bandage. Got a good deal,on some Israeli army bandages....
    1999 GU 4500 dual fuel
    Il dado è tratto
  6. #6
    Mar 2013
    For what its worth, what your first aid kit contains will really just contain the basics then what you want to tailor it to ie, where your are going and for who long.
    In general, a good kit will contain things like gloves, band aids, splinter picks, a few different types of bandages, a few containers of Normal Saline solution, a packet of Paracetamol tablets, a few non stick dressings, a pair of tweezers and scissors and that s about it. There are a few versions of this but generally they are pretty much the same.
    In my opinion and my experience, a good first aid kit should contain the following;
    Gloves- If it's not your blood, try to keep away from it. Also, they protect the patient from anything ban that may be on you.
    Hand Cleaner- To be effective, the alcohol should be above 70%. Good to clean up with both before and after. Also handy when you 'Gotta go' while out bush.
    Some Medi-wipes of Alco-swabs- Great for cleaning around dirty wounds but very painful for the patient, so please be gentle.
    Decent band aids- All too often, the band aids that are included are one of two sorts... either they don't stick well enough (usually because the skin is too wet) or they stick too well and react with sensitive skin on a lot of people. The type I prefer (I don't intend to promote any brands ,just recommend decent products) as wound dressings are primapore dressings. They come in a range of sizes, are hypoallergenic and stick really well. (I actually carry a 50mm x 5m role of Hypofix (a hypoallergenic self adhesive tape) and an assortment of different sizes of Melanin non stick dressings. This way, I can pretty much dress any size wound, including fingers and toes.
    Steri-strips- AKA Butterfly stitches. Very handy for closing deeper cuts. *IMPORTANT TO REMEMBER* If you are closing a deepish cut, it will need to be cleaned thoroughly as any dirt left in will cause infection later on because the skin edges are back together, they will start to heal.
    Sodium Chloride 0.9% for Irrigation- Great for washing/cleaning out wounds. The size container you get will depend on the size of the first aid kit you carry. The come in 10ml, 30ml containers. Also great for cleaning out any eye irritations.
    Compression Bandages- make sure that you get the compression bandages. One of the biggest dangers in the bush are snakebites. Normal dressings are no good for snake bite as they can't apply enough compression but compression bandages are great for sprains, strains and soft tissue injuries as well as snake bites.
    Large quantity of Cotton Swabs or Combine Dressings- Great for cleaning up blood, ooze etc.
    Triangular bandages- for the obvious injuries requiring a sling plus, in hot clims they can be soaked in water and used as a cooling bandana.
    Thermal Blanket- Despite common beliefs, it can get frickin cold in the desert at night!
    A decent set of scissors and tweezers- very handy and you'll be surprised at how useful they are.
    Splinter probes- You'll be amazed at how many sharp things there are out there.
    1 x packet each of paracetamol (for headaches etc), ibuprofen (anti-inflammatory), an anti-histamine (for allergic reaction or insect bites).
    Folks, this isn't a hard and fast list of what should be in a first aid kit but its a good start.
  7. The Following 5 Users Say Thank You to Gecko17 For This Useful Post:
    Avo (11th August 2014), briscott (9th August 2014), Clunk (12th August 2014), my third 256 (10th August 2014), snicko (9th August 2014)
  8. #7
    May 2011
    mackay former alice boy
    As well as the normal kit resus mask with 1 way valve ,Ventolin ,and super glue .
    U have 4 choices in life :U can like it; lump it; love it or shove it, take your pick and stick to it !
  9. The Following User Says Thank You to dads tractor For This Useful Post:
    Gecko17 (10th August 2014)
  10. #8
    I stocked mine via the chemist, for most camp site scenario, burns and cuts.
    Also be aware if you haven't used it, as some of your creams etc may have gone past their "used by date".
    I now pack a small tube of super glue too.
    My BIL packed my kitcken knives in a milk crate once handles down, I went to find something you can guess the rest.
    I would love an EPI pen but they are on prescription..
    I'll up grade all the time, I have a first aid sticker on my Patrol as well
    Other things from memory are elka selka and some panadeine Forte, Asprin, eye drops,
    and a finger guard, trust me you'll know if you'll need one and an eye patch
    Late edit Ungvita I love this stuff great for cuts and grazes.
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #9
    Mine is a basic 100 or so peice kit but stays in the car at all times..
    Never know when you'll need it
    Mar 2013
    Quote Originally Posted by dads tractor View Post
    All brilliant items to carry.... if you have ever had to do a resuscitation, it is all too common that the patient will throw up (especially when drunk) and the idea of a one-way valve mask is that you don't get to share that with them! (Oh the stories I could tell...)
    Ventolin is another really good item as it is quite common to come across asthmatics or even people who aren't but on really dry cold nights, suffer breathing difficulties. Just keep an eye on the expiry dates.
    Super glue is great for cuts that are on broad planes but no good where there are folds or creases in the skin as it will crack and disintegrate once dry. You must ensure that the wound is cleaned thoroughly and without any anesthesia, this can be very painful. Also be careful if there is nerve damage as this will need to be operated on by an orthopod.
  14. The Following User Says Thank You to Gecko17 For This Useful Post:
    dads tractor (10th August 2014)
