Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Bigger tyres , by how much does it effect speedo accuracy ?
  1. #21
    Quote Originally Posted by Limmy View Post
    i just downloaded an app for android mobile called SPEEDVIEW . uses GPS for speedometer . I will test it later
    I tried this app and its the same as my GPS, so got confirmation that the speedo is out, even though I'm running standard size wheels and tires. Did notice that it has a 1/4 mile time as well. Interesting to see who has the slowest patrol.
  2. #22
    Jan 2013
    Going from 31s to 33s. The speedo reads 94 when im doing 100. So 6%
  3. #23
    Quote Originally Posted by Dales300exc View Post
    What did it read with 31's
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    With 33s on my gq my speedo is spot on with 1km/h
  5. The Following User Says Thank You to 93patrol For This Useful Post:
    BigRAWesty (8th August 2014)
  6. #25
    Jan 2013
    It read pretty darn close to 100 at 100.
  7. #26
    North brissy
    I have found this is pretty much infinitely variable as every patrol seems to be different. A few examples- my gu was correct with 285/75/16 tyres, my sisters gq is out 5km with 31/10.5/15 tyres and her boyfriends gu was correct with 35/12.5/15s fitted.
  8. #27
    Same. Mine has come out spot on with 33's and 4.1diffs.. But others are way over.. Or under.
    If I ever change to 4.3 diffs it'll revert back to close to 6k under like my 31's were
    Apr 2014
    I went from 31's to 33's on my GQ and the speedo is actually on the money now .. checked with 3 or 4 different GPS's...just to be sure
    All depends on how far and which way your speedo is out in the first place..
