Results 1 to 10 of 13
Thread: GU Rear Shelf - about $100, easy as.
    Advanced briscott's Avatar
    Jul 2014
    Hey blokes, I needed to knock up a shelf for the back of my truck and wanted it to be light, cheap, easy and look neat. It didn't have to hold lots of weight, I intend using it for lighter stuff.
    So I thought about it for about 15 minutes, headed down to Bunnings to buy a fence panel and a post.
    Total cuts were 3 - knocked the post in half to make bearers, cut the panel in half to make the shelf (top and bottom cut). All with the hacksaw.
    The Z brackets bolt down to the 3rd row seat holes with the original bolts, the rest is just zinc bolts/washers with nylock nuts.
    2400x900 fence panel - $59;
    1800x50 fence post - $20;
    50x100 Z brackets - $3.50x4;
    50x50 end caps - $1x3 (post comes with one);
    4 x 4" 5/16 bolts, 4 x 3" 5/16 bolts - nuts and washers to suit - $10;
    2 x ~8-10mm 50x50 spacers for the rear Z brackets - free out of a bit of spare timber.
    No paint required unless you want the heads of the bolts done.
    Cost - $110
    Total time to build - 2.5hrs
    Weight - Not sure - 5-7kgs plus the mat??
    I did buy a 1200x850 rubber mat from Bunnings for $29 which is pictured, what is not pictured is the ply ($9) to spread weight across the bars. A tip though if you do something similar is to whack a rubber mat ($7.50) from bunnings under the timber to stop any bounce noise - or attach each slat to the board.
    Without the ply, the shelf if fine to put shopping/baggage etc etc on. The mat is quite heavy, grippy and has knobs on the back that give minimum deflection between the slats.
    The slats are welded both ends from the factory, but I wouldn't concentrate 20kg on a slat or two. With the ply in place though, the thing will hold pretty reasonable weight.
    Getting it out is easy, it comes out in a single piece. Undo the 4 seat bolts and its done.
    Great dealings with: Rex;
  2. The Following 8 Users Say Thank You to briscott For This Useful Post:
    BrazilianY60 (13th December 2024), gaddy (4th August 2014), jackbyo (30th June 2020), MudRunnerTD (13th April 2021), mudski (3rd August 2014), my third 256 (20th May 2015), phtest (15th September 2014), threedogs (4th August 2014)
    334 Post(s)
    Good job mate, looks good
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Looks good mate. Good thinking
    Lucus30's 1999 GU ST TB45E
    Western suburbs of Melbourne
    12 Post(s)
    Great idea, would be strong enough to hold a bit of weight, but weight on (I'm assuming aluminium fence) when bouncing around might buckle.
    But I love the idea. Up here for thinking.
    Jul 2014
    Yep, needed something for clothes/bedding/chairs etc - lighter stuff. I'll bolt the ply on it, it should distribute the weight well enough to carry a bit more. I wouldn't sweat putting a full esky on it 'on road', might knock up some removable posts for the middle. Didn't put any in as I want to slide a table under it.
    edit - Just looked at the pics, might add some swing down legs, could easily fit 3 across the door end and one at the seats end.
  7. The Following 2 Users Say Thank You to briscott For This Useful Post:
    Ibbo (24th June 2015), MEGOMONSTER (4th August 2014)
    12 Post(s)
    Quote Originally Posted by briscott View Post
    With nice bit of ply on it, it should be enough not to have a middle leg.
  9. #7
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    what a great idea, tanks for sharing
  10. #8
    Jun 2015
    Queensland
    Awesome idea!
  11. #9
    Expert Skitzyrex's Avatar
    Jul 2013
    Done one up for my car also. Was $60. Just used some security mesh from the salvage yard and some 20mm square tubing. ImageUploadedByMotorculture1434872195.945251.jpgImageUploadedByMotorculture1434872213.223366.jpg
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  12. #10
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    That's exactly the kind of thing that makes this forum so good. Ideas like that shared. Thanks mate.
