Results 1 to 10 of 17
Thread: Tap tap tappity effing tap!!
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Hi all
    There is one very annoying noise that I have spent months trying to knock on the head. It sounds like it's in the cab in the drivers footwell. It's not a clunk or bang, but a little tap sound, sort of like a plastic electrical connector tapping on the firewall or something. I have cable tied every bit of electrical wire, plug, hose, bonnet cable, everything I can see. But I'm at a complete loss as to what it could be.
    Is there anything within the pedal assembly that tends to make a tap noise?
    If I'm driving over bumps, it makes the noise, if I speed up or slow down, this also makes the noise.
    The car has all new bushes, new body mounts and isn't making any suspension clunking noises.
    If anyone has any suggestions, please throw them at me.
    Andy
    Nothing behind the RH kick panel, or something like a flasher cam hanging under the dash
    Expert @GUte's Avatar
    Aug 2013
    Beechworth, Nth East Vic
    Stressed metal flexing?
    Jan 2013
    Nowra NSW
    5 Post(s)
    Flasher can is secured. I've removed all panels, even the fuse box to make sure nothing was loose behind. Everything is secured. With regards to the metal flexing, I wonder how I could test for this?
    Aug 2013
    Quote Originally Posted by Parksy View Post
    Yeah buggered if I know mate. If you are absolutely sure nothing is loose under the dash it's worth considering.
    My wagon had a similar sound but it's now parked up in the paddock before I found the annoying racket.
  6. The Following User Says Thank You to @GUte For This Useful Post:
    Parksy (24th July 2014)
    could it be something in the inner guard like the plastic bit flapping? or old antenna lead
    In between the battery and the guard?
    Just throwing stuff out there
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #7
    84 Post(s)
    Had the same problem in our Toyota van. After extensive searching, it turned out to be dried grease inside the steering column. It was sticking to the plastic wear pads and dropping them. It made a clicking tapping noise and droves us nuttier than we already are. I have just looked at the GQ steering column in the manual, but it doesn't seem to have the same set up. Maybe something to check out though.
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #8
    Jul 2014
    Auckland,NZ
    Have similar problem with my 1991 Safari, feels like something intermittently thumping under my feet. Only happens once in a while and as hard as I've looked I can't find anything that seems like it could be responsible. Not much help I'm afraid but thought you'd take some solace knowing your not the only one being driven loopy.
    Happy hunting, Lee
  12. The Following User Says Thank You to sprdad For This Useful Post:
  13. #9
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks all for your replies. The steering column idea is interesting. As is the inner gaurd idea. I wonder how hard it is to remove a patrol steering column?
  14. #10
    Jul 2012
    North East Victoria
    4 Post(s)
    I know how annoying such noises can be & how hard it is to actually isolate the area that they come from ( or maybe that's just my poor hearing ) . Once had a noise from passenger side of my ute that only occurred when someone was in the seat.Took ages to find. Turned out to be the ratchet mechanism in the seat belt locking & unlocking as we traveled - didn't have to be a rough road . Of course if you are certain that in your case the noise is coming from the footwell then your search for the cause will go on.
    Remember that a high IQ doesn't make up for a lack of common sense.
    Learn from the mistakes of others - you won't live long enough to make them all yourself !
