Results 1 to 10 of 15
Thread: Big end oh no!!!
    Apr 2013
    Mount Nasura
    Thumbs down Big end oh no!!!
    So I dropped the bus off last night to have the rear main seal replaced, noticed it was leaking on Thursday, didnt drive it again until yesterday to drop it off at the mechanics, plus checked the oil and there seemed to be plenty in it.
    The mechanic rang, advised that it was bone dry so they filled it back up and apprently she has a nasty knock now, suspect the big end bearing. I havent been back to the mechanics to check it out yet, headed there after work.
    She was driving like a dream besides leaking a bit of oil so I dont really understand how now all of a sudden she is knackered.
    What I want to know is, if the big end has to be replaced am I looking at a complete rebuild? If so can you WA fellas recommend someone to do it?
    Pretty gutted at the moment as you can imagine and am still in a bit of dissaray as what to do next.
    Any help as always greatly appreciated.
    2008 GU ST Bog stock and no smoking barrels!
    Thomastown, Melbourne
    6 Post(s)
    All sounds a bit odd to me???
    So you have not heard the car run since you dropped it off.
    Apr 2013
    Mount Nasura
    Na mate, still at work so havent heard it yet.
    Have rung Robson Bros and TT Automotive and both think it is a bit suss, especially for my vehicles age, 2008 and kms, has only done 115000.
    Have got a verbal indication at about $4k for a crank regrind and big end bearing if it is that, will def be after a second opinion.
    I had no oil light come on or anything while I was driving it.
    Legendary happygu's Avatar
    Beni,
    No oil can do that - and it will flog out the bearings fairly fast......
    Did you check to see if there was still oil after you dropped it off, as if there was then that tells a different story
    Depending on what damage has occurred, you could look at just removing the sump, check the bearing shells and crankshaft. If the crank is OK, then it may be only a matter of replacing the bearings, and reassembling.....
    Let's hope that there is no more damage, as no oil could also mean scoring or pickup in the piston bores, which would then facilitate a full rebuild
  5. #5
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    Quote Originally Posted by Beni C View Post
    Go with your gut feeling. Does sound a bit suss. Don't let them bully you into anything either.
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
  6. #6
    Apr 2013
    Mount Nasura
    Happy, I didnt check the oil after I dropped it off mate, perhaps I should have but there was no indication, she was running fine nnd no engine light.
    I know where I parked it when I dropped it off so will be having a good look to see how much oil is on the ground. The leak was evident but not massive, she wouldnt have been loosing litres thats for sure.
  7. #7
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    Beni,
    what a bummer.
    Not experienced anything like that (touch wood) so can't help.
    However, if you had a leak which you were taking it in to get fixed, it's just possible that on the way the seal/gasket whatever gave way big time but you got there just before the big grinding got obvious. Big oil dump on the road and not much at the mechanics. Be a big coincidence maybe but maybe possible as well.
    Luck,
    Col.
  8. #8
    176 Post(s)
    I sincerely hope it wont be necessary, but if it is I do have a recommendation. One I like to give because in my 27 years in Australia this place is the ONLY workshop I have ever experienced that I am confident to recommend. They are top notch. They are a combined workshop & engine reconditioners with all the latest top quality diagnostic & machining gear under one roof. They are also one of the very few workshops where I have felt properly listened to. I recommend them without hesitation.
    Avon Precision Engineering Service, Northam, WA
  9. The Following 5 Users Say Thank You to Cuppa For This Useful Post:
    Avo (23rd July 2014), Beni C (23rd July 2014), DX grunt (24th July 2014), mudski (22nd July 2014), snicko (23rd July 2014)
  10. #9
    Jan 2014
    Perth Wanneroo
    Sounds a bit suss losing almost all oil through rear main seal. Oil splashes into this area and is unlikely to flow out freely without a complete seal failure.
  11. #10
    Apr 2013
    Mount Nasura
    Thanks fellas.
    So went down to the mechanic last night, ever the slightest knock coming from the big end, I had trouble hearing it so hopefully we are onto it early and only the bearing needs to be replaced. She is on her way to Robson Bros today for further diagnosis.
    Will keep yas posted as to the progress.
  12. The Following User Says Thank You to Beni C For This Useful Post:
    Bloodyaussie (23rd July 2014)
