Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Cheap Battery monitor.
    Ballarat, Vic
    176 Post(s)
    http://www.ebay.com.au/itm/180957166...84.m1423.l2649
    These look like a useful bit of gear. Monitors that do what this one does usually cost $200 to $400.
    Comes with the shunt & shows voltage, amps in & amps out, battery percentage (State of Charge), time to full charge (at current charging rate) & more.
    In fact it does all that my NASA BM1 ‘Compact’ monitor does which I bought at a bargain price of $140 (usually closer to $240).
    I have no direct experience of these units but do know of one person who is using one successfully & he is not someone likely to accept rubbish.
  2. The Following 12 Users Say Thank You to Cuppa For This Useful Post:
    Bloodyaussie (15th July 2014), Family4x4 (15th July 2014), Gavshe (26th May 2015), graeme1969 (15th July 2014), Hodge (15th July 2014), krbrooking (15th July 2014), macca (15th July 2014), Maxhead (15th July 2014), mudski (21st July 2014), my third 256 (16th July 2014), oncedisturbed (31st July 2014), Yabb (15th July 2014)
    Thomastown, Melbourne
    6 Post(s)
    Worth a punt at that price...
    176 Post(s)
    Well spotted Cuppa. Since i'm doing my dual battery system as I type this, I was after something like this. Hmmm Buy button is.... tempting.
    Patrol Guru Family4x4's Avatar
    Jan 2014
    Victoria
    Thanks Cuppa would this unit be able to monitor both batteries? Would it be as simple as adding a switch if it doesn't?
    In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
    Theodore Roosevelt
    brisbane
    Do it mate one of us has to be the Guinea pig lol I'll be curious to see how it goes
    brisbane
    Quote Originally Posted by Family4x4Fun View Post
    The switch would probably depend on if when switching the unit between batteries it turns the unit off then you will have to reset the ah capacity of the batteries loosing your current place but it looks like there are two pos inputs so one may be for the amps reading and power and the other volt reading.
    I think it would work looking at it closer.. But maybe put a momentary switch on the pos powering the shunt so you don't forget to switch it back..
  8. The Following User Says Thank You to megatexture For This Useful Post:
  9. #7
    Ballarat, Vic
    176 Post(s)
    Not really. The way that these monitors are able to be used as a ‘Battery fuel gauge’ is by first the capacity of the battery being set by the owner. Eg. 100Ah. When the battery is full (determined by voltage) any usage draws Ah’s from it. The monitor can then tell how much of the capacity, as a percentage, has been used. Likewise it can add Ah’s when being charged.
    They are smart enough to recognise charging & usage at the same time. It is not uncommon for my monitor to show +ve amps from the solar whilst the fridge is running for example, because there is more coming in than is going out.
    The problem with switching between two different batteries is that each battery capacity would likely be different, meaning the monitor would need to be reset. Even if they were exactly the same it would still take a little while for the monitor to suss out the other battery’s SoC. So not really practical. Besides I can see no point monitoring a start battery in this way. As long as it has sufficient voltage to start the vehicle that is all that is needed, & most dual battery systems have a means of protecting against draining the start battery.
    For setups with more than one aux batteries, this meter could monitor both if they were connected to each other (would see them as one large battery). If it is desired to not connect them together then a separate monitor for each battery would do the job.
  10. The Following User Says Thank You to Cuppa For This Useful Post:
  11. #8
    brisbane
    It would be able to switch for volts
  12. #9
    Ballarat, Vic
    176 Post(s)
    Quote Originally Posted by megatexture View Post
    I would be able to switch for volts
    Yes you could switch just for a reading of voltage & real time amps in or out, but could also achieve this with a simple volt/ ammeter. The same seller has such combo meters too.(& they are cheaper).
  13. The Following User Says Thank You to Cuppa For This Useful Post:
  14. #10
    brisbane
    What were you trying to achieve? Car dual battery or a camper setup ?
    I'm tempted to get one just to see what its like lol . HMmmm
