Results 1 to 10 of 14
Thread: Heater not working? air lock?
    Expert Cbates's Avatar
    Lilydale
    Hi guys,
    my heater isn't working on my 99 gu tb45 on gas.
    i think their might be an air lock.
    is there a way to get an air lock out of the heater core hose without taking the core out?
    thanks
    Corey
    Possible it could be clogged with goo make sure the
    lever is working and fully opening , to allow full water flow.
    If you think you have an air lock park nose up and invert a coke bottle in the radiator to raise your fill point.
    Should remove a lot of air this way make sure heater is on hot and working
    Cbates (9th July 2014)
    Lilydale
    thanks for the advice, did what you said but seems that theres no more air coming out of the radiator.. any other suggestions?
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    With the engine at running temp, feel for heat on the rubber heater hoses, this may give you a indication of where the hot water is getting stopped, if the heater is on, and only one heater hose entering the firewall is feeling hot, your core will most likely be blocked, or the tap is not working.
    If this is the case, in the engine bay, pull both hoses off where they enter the firewall (only when the engine is COLD again), put your garden hose in one hose entering the firewall, and turn it on soft, water should flow easy back out the other hose, this will confirm water is flowing through the core. (make sure heater tap is open)
    Ive seen big brown poo like blockages come out of heater pipes before doing just this.
    If you clear a obvious blockage, put one hose back on, and fill the other hose with water until it flows out of the engine side (to get rid of air), you will still need to bleed the whole system again (as 3D suggests), but this should be enough to check the heater now works.
    If you do get a poo from the core, you need to carefully monitor the coolant level, and the core for leaks , as sometimes the poo causes corrosion, but at the same time, the poo stops water getting to any corrosion holes so you don't actually see a leak until the poo is gone.
  6. The Following User Says Thank You to 04OFF For This Useful Post:
    MudRunnerTD (9th July 2014)
    Poo was the word I couldn't think off, lol
    Brisbane,QLD
    12 Post(s)
    Yeh, I thought what other description can I use, but when you see one come out, there really is no better way to describe it, fortunately they don't smell that bad though (lol)
  9. #7
    rlmao yeah once you've seen it once it never leaves you
  10. #8
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Hi Corey,
    Good to see you back on the forum, sorry can't help with the heater but good info from 04OFF and TD, the coke bottle works.
    Let us know how you go.
    Jack
    2024 Isuzu MUX
  11. #9
    Lilydale
    Got it sorted! took the heater hose off and put pressured air through the radiator cap! big blockage but got it out! thanks mate! been a while!! working on my other project.. 63 vw bus
  12. The Following User Says Thank You to Cbates For This Useful Post:
    jack (9th July 2014)
  13. #10
    477 Post(s)
    Welcome back Corey!
