Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: For the brake genius out there.
  1. #51
    178 Post(s)
    G`day All
    Cuppa to answer your question, it`s exactly what we want, that is for the cups to move out then when they return the agitation of the fluid drags the little air that is left in the cyl, out.
    That makes sense, allowing max movement of the cups. I can imagine in that scenario the 'timing' of opening the bleed nipple might be super critical, more so than in 'normal' bleeding procedure.
  2. #52
    When we bled the brakes after fitting new rotors and pad, the boys at TJM Coburg have a 4 into one system..
    As in hooked up all four bleed nipple, took a couple of them to do it, as well. But the gravity system works best if you have the time
  3. #53
    Oct 2010
    Old Bar, NSW
    Here's some more information.
    Left photo, car is tilted 55degrees to get port to the very top.
    Right photo, what Pearcy is talking about. Wrap the pistons with tie wire to bleed and carefully install then push the into correct position using brake pedal.
    I like that best, not perfect but better. Add rubber grease and all air would be displaced.
    Food for thought.
    Now I have to knock dent out of the shed wall where I was hitting my head!
    Macca
  4. #54
    Yours as you have just said is disc all round and does not have the problem these guys are having with their drums.
  5. #55
    Oct 2010
    Old Bar, NSW
    Caught up with a mate last night, he is a mechanic at the local Nissan dealership.
    They don't get to work on Patrols any more as most are a few years old and never get taken in for warrantee and services etc.
    Showed him the slave cylinder and was amazed by the design, he did not know of the problem and had not heard anyone talk about it.
    He was going to ask around and get back to me.
    His dad is also a mechanic, although this was new to him, he said with something like this you compress the pistons together as Pearcy said then pump the pedal and hold it down hard to pressurise the system, release the bleeder and the force of fluid rushing in swirls the fluid and air out get "most" of the air. He had not done it but that was his solution.
    Bugger of a thing
    Macca
  6. #56
    178 Post(s)
    This is what really astonishes me. Will be interesting if he hears any more. It's hard to believe that the issue has gone unnoticed by Nissan. Would also be interesting to know if it's only a leafy GU issue, or other leafy models too.
    Are there any ex Telstra mechanics here?
  7. #57
    Cant park the girl sideon on a hill? then do the final bleed?
  8. The Following User Says Thank You to timmay556 For This Useful Post:
    macca (14th July 2014)
  9. #58
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by timmay556 View Post
    At 55 degrees, you are braver than me LOL
    http://www.nissanpatrol.com.au/forum...7&d=1404797356
    Macca
  10. #59
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Chicken
    Jack
    2024 Isuzu MUX
  11. The Following User Says Thank You to jack For This Useful Post:
    macca (11th July 2014)
  12. #60
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by Apollofish View Post
    Chicken
    book, book book book hell yeah
    Macca
  13. The Following User Says Thank You to macca For This Useful Post:
    jack (11th July 2014)
