Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: For the brake genius out there.
    Oct 2010
    Old Bar, NSW
    I have fitted new front pads and rear slave cylinders (drums on the rear).
    I had to force the front pistons back to fit the new pads.
    Now I have a soft pedal, long travel before the brakes start to work.
    Pump the pedal and feels OK till next time.
    Hold foot on pedal and it slowly goes to the floor.
    We have bled the brakes twice including the proportion valve.
    Any ideas what is playing up.
    Macca
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Sounds like air still in the line. Start with the furtherest wheel away from the master cylinder left hand rear. Then RHR,LHF and finally RHF.
    Are you using Dot 3 or Dot 4 fluid
  3. The Following User Says Thank You to 93patrol For This Useful Post:
    macca (5th July 2014)
    Sounds like air still. What procedure are you using to bleed?
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Have you started the bleed in the correct sequence? Starting from the nipple furthermost away from the master cylinder?
    1999 GU 4500 dual fuel
    Il dado è tratto
  7. The Following User Says Thank You to NP99 For This Useful Post:
  8. #5
    Oct 2010
    Old Bar, NSW
    LR, RR, LPV, LF & RF. 2 person, open pedal down, close pedal up. Thinking if it's air it would not firm after pumping the pedal.
    Also the pedal going to the floor, could the master cylinder be leaking back past its piston.
    I don't know if I have the wrong end of the stick.
    It's doing my head in.
    Macca
  9. #6
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by 93patrol View Post
    Just checked its Dot4
    Macca
  10. #7
    Sep 2011
    adelaide
    18 Post(s)
    Forget about the bleeding sequence as the master is split in to two separate systems and it doesn`t matter where you start.
    What your problem sounds like is the master is bypassing to check this clamp the hoses going from the body to the DIFFS then see if the pedal slowly goes to the floor, if it does then the master needs to be replaced. If the pedal is solid then the master is OK. If OK release one clamp and check then reclamp and release the other clamp. This will tell you which end has the problem.
    You can clamp the hoses off with a couple of G clamps BUT DO NOT clamp braided hoses.
    Hope this helps
  11. The Following User Says Thank You to pearcey For This Useful Post:
  12. #8
    Oct 2010
    Old Bar, NSW
    Pearcey that sounds like a good way to fault find, that's what I will try tomorrow, report back with my findings. Thanks mate.
    Macca
  13. #9
    Sep 2011
    adelaide
    18 Post(s)
    When bleeding the system, bench bleed the master or start at the master then go to any wheel it doesn`t matter which and with help get someone to push the pedal down then open the bleeder, then shut the bleeder, get the person to SLOWLY release the pedal TAKE FROM 5 to 10SECONDS wait a couple of seconds then have them depress the pedal again when they have depressed the pedal open the bleeder, repeat this until you have new fluid flowing at that bleeder. Do the same at each wheel and you should be successful. By pumping the pedal as most do can create problems where when the pedal is released fast air is drawn in past the cups in the wheel cylinders.
    Any problems pm me, 45 years a brake specialist.
  14. The Following 3 Users Say Thank You to pearcey For This Useful Post:
    macca (5th July 2014), menace 2 (8th July 2014), Wizard52 (7th July 2014)
  15. #10
    Sep 2011
    adelaide
    18 Post(s)
    Sorry macca I missed the 2000 posts as I just got back from Tas CONGRATS mate
  16. The Following User Says Thank You to pearcey For This Useful Post:
