Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: Paule starting NADS
  1. #51
    476 Post(s)
    Quote Originally Posted by Paule View Post
    Cheers for your 2 cents boots, I did take the solenoid off the top of the turbo when I was struggling to get the heat shield off ( I now no I didn't need to), but im 99% sure that I got it all back in the exact spot it was in. I didn't touch the grub screw. If cleaning the maf doesn't work do you think I should make actuator screw longer or shorter?
    Your a brave man touching the actuator arm. You eff this up and it will make things worse. Just come over to my place, I have a good 2nd hand MAF here you can try if you like.
    Paule (2nd July 2014)
  3. #52
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    G'day mudski, thanks for the offer mate you are a champion. I just cleaned my maf sensor. So we will see how that go's if that doesn't help I'll let you know.
  4. #53
    476 Post(s)
    No problems mate. If your maf is stuffed, cleaning it is not going to help though. But it's certainly worth trying anyhow.
    Paule (6th July 2014)
  6. #54
    Jan 2014
    Sandhurst
    Ok nads are all done, thanks for everyones help. Onto the next mod. Lol. I can get a 2nd hand Nissan winch bar, first question what are they worth? 2nd question, will it fit the runva 11xp? And are they a good bar?
  7. #55
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Can't help you with the $$ but the factory nissan steel winch bars were all made by ARB so they are decent. The Runva 11xp fits in nicely to the bar, I just installed mine last week before the trip and I know a few other guys here have got them as well. I've got a bit of a write up in my build thred for the winch install if you go down that track
  8. The Following User Says Thank You to Bacho86 For This Useful Post:
    Paule (16th December 2014)
  9. #56
    Advanced jonez911's Avatar
    Oct 2014
    hey paule was it just your maff that was causing the issues?
    im just about to start this process and getting my head around all the issues that can arise
  10. #57
    Jan 2014
    Sandhurst
    Quote Originally Posted by jonez911 View Post
    No I ended up setting max boost (Dawes) to 14 psi and just kept tweaking my needle valve so it wasn't spooling up so fast
  11. The Following User Says Thank You to Paule For This Useful Post:
    jonez911 (16th December 2014)
  12. #58
    how are your egt's at say 100K freeway
  13. #59
    Jan 2014
    Sandhurst
    Egt's on 100k flat road freeway are about 250 C. Boost is at about 8 psi
  14. #60
    476 Post(s)
    Nice and cool...
  15. The Following User Says Thank You to mudski For This Useful Post:
    Paule (17th December 2014)
