Results 1 to 8 of 8
Thread: slotted brakes.
    Advanced batesy's Avatar
    cranbourne vic
    slotted brakes.
    http://www.ebay.com.au/itm/161107723...84.m1423.l2649
    Hi does anyone have these they look okay cheers.
    No I have RDA dimple drilled and slotted with Green pads from
    performacecarpartsonline and only cost me $100 a corner
    batesy (2nd July 2014)
    cranbourne vic
    I've heard not to get dimpled just slotted, these work out the same price & there RDA so should be good i reckon.
    The ones to avoid are the ones that are drilled traps mud etc and tend to crack as well.
    very happy with the stopping ability now chalk and cheese compared with before,
    Cuppa did similar on his ute and equally pleased with the outcome, he use black pads
    from DBA but they are the same as green by all accounts
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Ballarat, Vic
    178 Post(s)
    TD, have you been taking too many meds mate? YOU are the one with the black pads (Bendix?), not me! I have EBC 6000 series Greenstuff pads. Both on the RDA dimpled & slotted ..... you got that bit right. LOL.
  8. The Following 4 Users Say Thank You to Cuppa For This Useful Post:
    batesy (2nd July 2014), Dales300exc (2nd July 2014), FNQGU (8th July 2014), threedogs (1st July 2014)
  9. #6
    cranbourne vic
    Thanks for that will have a look around.
  10. #7
    Hardcore
    central coast nsw
    Drilled are reported to crack around the holes, where-as the dimpled are not completely drilled through and are not suppose to crack as a result.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  11. The Following User Says Thank You to Robo For This Useful Post:
    batesy (9th July 2014)
  12. #8
    cranbourne vic
    I ended up buying DBA T2 series slotted http://www.ebay.com.au/itm/221165082...84.m1439.l2649, think they should be ok.
  13. The Following User Says Thank You to batesy For This Useful Post:
    Clunk (9th July 2014)
