Results 1 to 3 of 3
Thread: how to fit new steering damper?
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    Hi guys,
    I have a new steering damper and want to know how I go about fitting it. It is for a 89 gq and and the original goes from the chassis to the drag link and is eye/eye. The new amarda is pin/pin and goes from a superior panhard (which I have) to the original drag link. I have a bracket for the old drag link but do I need to cut the old one off and where to fit the bracket? do I pull out the damper halfway or is there a measurement?
    Thanks Rob
    GQ Snorkle Lockers front n rear
    North brissy
    Turn it all the way to the lock where the damper will be at compression then fit it (or extension) whatever you find easiest.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    89gqpatrol4x4 (20th June 2014)
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    And do it on a concrete surface....
    1999 GU 4500 dual fuel
    Il dado è tratto
  5. The Following User Says Thank You to NP99 For This Useful Post:
