Results 21 to 30 of 38
Thread: 2 Din head unit flashes from day to night mode when rh indicator and brakes are on.
  1. #21
    Hardcore
    central coast nsw
    Try using a hose at least you can then control where the water is going to further narrow it down.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  2. #22
    476 Post(s)
    Since posting this it still hasn't done it. It usually will do it every day, give or take, but not since.
  3. #23
    Oct 2013
    Port Hedland
    Sounds like you have the dimmer wire connected to the indicator wire not the dash lights
  4. #24
    476 Post(s)
    Definitely not as if I did it would do it all the time.
  5. #25
    Hardcore
    central coast nsw
    So how did we go any news
  6. #26
    476 Post(s)
    Quote Originally Posted by Robo View Post
    Late reply but, I ran an extra earth wire from the earth of the indicator to the body. All fixed. Now when I press on the brake pedal, it happens. Not all the time though. I think I will run another earth lead from the -ive of the battery to the chassis and see what happens.
  7. #27
    Bloody GUs and their earth problems.
    I know Toyota earth different sections of the 4x4 like
    engine bay, cabin and cargo area, motor to chassis and body to engine/chassis
    but I suppose you can never have enough earth straps eh
  8. #28
    476 Post(s)
    Yeah I think I might do, -ive to chassis, and chassis to engine aswell. To be sure, to be sure...
  9. #29
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Are you running LEDs in your tail lights? If so try replacing the high mount led with a standard bulb and see how that goes.
  10. The Following User Says Thank You to Yendor For This Useful Post:
    mudski (23rd October 2014)
  11. #30
    476 Post(s)
    Yeah I am Rodney, but not all. But the original issue with the indicators was prior to the LEDs. The only globes that aren't led is the brake light on the barn door, the indicators and stop tails in the rear quarter lights. The rear lower indicators have resistors fitted. Do I need them for the brake lights too?
