Results 1 to 10 of 11
Thread: TD42 turbo kits
    Jun 2014
    TD42 turbo kits
    hi guys
    i am looking to get a turbo kit for a TD42 engine, can you recommend a good brand? i was looking safari brand turbo kit.
    also, should i even turbo charge would super charging be better for peformance?
    thanks
    Turbo for sure. The TD42 loves a turbo.
    For a full bolt on kit I think a kit from MTQ is great value and good performance . You can get bigger turbos and bigger performance but as an all rounder with good output and little stress on the motor the MTQ kit is a winner.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Alitis007 (15th June 2014)
    Jun 2014
    cool
    just checked them out. Would the intercooler improve peformace if installed?
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    Most defiantly improves torque and helps keep egt's down win win.
    Yes there are other options for an in get cooler though as the MTQ IC is pretty expensive I reckon. If you have the cash to do the turbo and IC at the same time then check out the across Country Top mount IC. It is bigger than the MTQ and I think better value.
    Jun 2014
    hey guy new to here and was just looking for some turbo info myself.
    ive just bought a silver top td42 GQ and I have a mate who is giving me his GU factory turbo. ive already got a GU airbox but was wondering in the way of intercooler if the GU factory top mount would work or even fit. Id like to stay away from front mount as even though I know they may perform better the thought of having it out front collecting mud and gunk doesn't appeal. also I don't want to have to worry about running pipes and hoses all around the joint which may hamper other things I would like to look at doing.
    cheers guys
    Hey Dakka. You could probably make the GUIC fit, I have not heard of anyone doing it though as they are notorious for leaking and under performance. But free is free.
    If you search the forum you will find a comprehensive thread on fitting the GU turbo to a GQ. AB the admin here did a great thread and a few others have followed suit.
    Good luck with your project.
    Quote Originally Posted by dakka1 View Post
    cheers guys
    But hey Dakka,
    Head over to the Introduction section mate and post an intro thread please. We like folks to say g'day when they first come here then ask any questions you like. Say g'day first though please.
  10. #9
    Jun 2014
    Hey Dakka, fan of Orks are we?
    I really like the look of the MTQ kit with the intercooler, pity the webiste doesnt give price. How much would the full kit cost and how difficult to fit to the engine.
  11. #10
    Jun 2014
    Hi guys, Im from Sri Lanka, I was fortunate to buy a brand new 2014 Y61 TD42 non turbo model. the vehicle is fantastic, however it lacks power on highways and while overtaking, therefore would like to get a IC turbo kit for it. I am very new to these stuff so do you guys think it will be reliable with the engine, and will i need to change the engine compression ratio? Further are there any other things that will be required to be done, or is it a simple bolt, if I buy say a Safari Turbo and an IC kit.
