Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: ciggy socket
    I just went out to have a look at the fridge and it says on 12v 6.25 amp. Isn't 50 amp overkill.
  2. #12
    176 Post(s)
    No it’s not. It isn’t just about the current carrying capacity, it is also to do with other attributes that the Anderson plugs have. They are ‘self cleaning’ meaning they will not build up a high resistance over time , & they are also a much more secure connection than cig & Merit plugs (& indeed most other connectors). It just happens that the smallest size is rated at 50amps. The cost is on par with merit or Hella type plug & sockets, in fact probably cheaper. (Hella type plug & socket are also superior to Merit as they have a much larger contact area & are rated at 15 or 16 amps).... but Anderson are best. There are a lot of cheap knockoffs of Anderson, some of which are reported to sustain oxidised connectors over time. Pay the extra dollar & get genuine Andeson with the silver coated terminals.
  3. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    jay see (10th June 2014), threedogs (11th June 2014)
  4. #13
    Thanks Cuppa
    As I'll said in the past electrical side of things isn't my strong point.
  5. #14
    Another question if I can.
    If I'm going to use an Anderson plug for the fridge, what happens to the cable and cig plug on the fridge. Do I cut and soldier on 8 mm wire and Anderson plug. Is it best to do this as close to the fridge or do I rewire it from the inside.
  6. #15
    176 Post(s)
    Unplug the 12v supply from the fridge & cut the cable to solder on the Anderson plug. It is quite possible the original cig plug will contain a fuse. If so you should add an inline fuse of the same rating between the Anderson plug & fridge plug.
  7. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    Bloodyaussie (11th June 2014), jay see (11th June 2014)
  8. #16
    OR you could buy the Engel/Baintech twist lock plug and socket
    again a secure fitting , Cig sockets are a thing of the past and IMO best avoided
    for any 4x4 application.
  10. #17
    Advanced elmo4eva's Avatar
    Dec 2013
    Just cut the wire on the main cigy n add switch then add those external ones
  11. The Following User Says Thank You to elmo4eva For This Useful Post:
  12. #18
    If you get stuck just come over we'll sort it out together, have every thing here to do it.
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #19
    Thanks all, I think I should be able to handle it.
    TD I'll give it a shot and see how it goes, but I'll hold you to the offer if it turns to poo.
