Page 39 of 570 FirstFirst ... 3738394041 ... LastLast
Results 381 to 390 of 5693
  1. #381
    Good idea but make sure you use silastic on the head of the bolt
    or your roof rack will fill up with water and rust from the inside
    Good add on td
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (6th June 2014)
  3. #382
    476 Post(s)
    Natural cure silastic too. Acetic cure will rust aswell...
  5. #383
    Patrol God Stropp's Avatar
    38 Post(s)
    I made a set of pins for a local bloke which go threw the holes on the tracks and mount to the roof rack sides.
    He wanted his welded but no reason why you couldn't simply drill a hole threw top rail and use a long bolt.
    Just drill a hole in the end for a ring pin or R clip or padlock to hold em on with and a bit or the foam floor matting spiked over the mounts behind the tracks to stop vibrations..
    no good for me westy, roof top tent does not leave enough length to attach them to the rack.
  6. #384
    @ Kallen theres a project for you Tracks carrier using the rear wheel carrier, similar to the old Hi-lift holders.
    Telescope some RHS and away you go,
  7. #385
    I got it yesterday. Oh well.
    Hopefully I will never need to use this.....but don't we all say that about all recovery gear.
    On a side note I got to meet threedogs, what a top guy and he knows his stuff too.
  8. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Hodge (7th June 2014), threedogs (7th June 2014)
  9. #386
    Back at you Jay Cee , John will be a great asset to the Forum I'm sure
    Married with a young family just old enough to get out there for some wheeling and camping.
    Another great bloke,
    And a nice looking Patrol just waiting to be modded as well.
    ps ditch the dickie seats and store them.LOL
    jay see (7th June 2014)
  11. #387
    Maybe next time we go camping and she will see how much room we loss. Besides I'm not to fussed about that looking forward to other mods.
  12. The Following User Says Thank You to jay see For This Useful Post:
  13. #388
    38 Post(s)
    Bought a handheld radio with a bullbar mounted antennae so I can monitor channel 10 on the Simpson and the channel we use or use one as a scanner.
  14. #389
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    Hi Stropp I planned on taking our handheld radio as well.
    I actually didn't realise another antenna was needed..duh!!!
    What sort of antennae did you use?
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
  15. #390
    38 Post(s)
    Quote Originally Posted by snicko View Post
    Snicko you don't need another antennae but the one I bought had one with it so I just fitted it up, it was a 4.5 db one for close range hilly conditions so you can pick up over the Sandhills, my other one has a 6.5 db for longer range stuff on the flat.
    If you get one just a 3db will be fine but you will need and adaptor to fit into your flexi antennae hole to the fitting on the cable.
  16. The Following User Says Thank You to Stropp For This Useful Post:
    snicko (8th June 2014)
